Trimming Shingles On Rake Edges - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-06-2007, 09:52 PM   #1
Rewards Points: 152
Trimming shingles on rake edges
What is the best way to trim shingles on the rake edges after installation?
sandyman720 is offline   Reply With Quote
Old 08-06-2007, 10:01 PM   #2
Rewards Points: 398
If the tiles are hot, you can trim them with a roofing hook blade and a straight edge pretty easy. I just used my metal cutting shears. It came out clean.
Malcolm is offline   Reply With Quote
Old 08-07-2007, 10:16 AM   #3
Malcolms answer is right on the mark.
Ed
Ed the Roofer is offline   Reply With Quote
Old 08-30-2007, 06:35 PM   #4
FatAugie's Avatar
What if they're cold (i.e. sun behind clouds, temp in lower 70's)?
Trying to cut Timberline Ultras is next to impossible.
FatAugie is offline   Reply With Quote
Old 08-30-2007, 06:40 PM   #5
Rewards Points: 398
Use shears.
Old 08-30-2007, 07:02 PM   #6
FatAugie's Avatar
Originally Posted by Malcolm View Post
Use shears.
You mean like Tin snips?
Old 08-30-2007, 07:49 PM   #7
Rewards Points: 398
Metal shears like these. I guess people call them tin snips. When I hear tin snips, I think of small aviation snips. Snap a chalk line and use these. you will come out with a smooth rake.
Old 08-30-2007, 07:50 PM   #8
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
Do you normally trim the shingles after installation?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-30-2007, 07:57 PM   #9
FatAugie's Avatar
Yeah, that's the kind I have (small aviation tin snips) and they weren't working for sh#t. I'll have a pair of these by noon tomorrow!
Old 08-30-2007, 08:30 PM   #10
Weekend Builder
Crackers's Avatar
I shoudl have read this yesterday!!!
I used a circular saw. It made a mess. Jig saw worked well, but still not perfectly straight. I am kind of p*(ssed off now, your experience rules.
Crackers is offline   Reply With Quote
Old 09-01-2007, 08:35 AM   #11
FatAugie's Avatar
You're right, they work great.
Also, I found that if I started at the bottom and worked up, it was a hell of a lot easier to trim straight.
Thanks everyone!
Old 09-02-2007, 12:29 AM   #12
the roofing god's Avatar
Send a message via MSN to the roofing god
usually use a hook blade and cut every 5 as their installed using a full shingle as an edge(line),you should only cut thru 1 thickness and make a 2nd pass on double piece areas,if you`re using snips,install a soldier course,flip the shingle upside down in place,mark it, cut it and nail it in place as finished item
the roofing god is offline   Reply With Quote
Old 09-02-2007, 09:19 AM   #13
FatAugie's Avatar
Question
what's a soldier course?
Old 09-02-2007, 02:23 PM   #14
it`s a shingle you install going vertical up the rake eave(side),say it`s 12"high shingle,you snap a line at 11" so the shingle overhangs 1" to set your overhang you nail it tight to the roof edge and it also adds strength against blow-offs
Old 09-02-2007, 02:24 PM   #15
also for marking upside down would be w/granule side up!
GAF Roof... the best EdPDX Roofing/Siding 73 09-12-2011 06:53 AM
Shingles per bundle redline Roofing/Siding 11 09-11-2011 11:41 PM
Over-trimmed shingles are driving me crazy pipeguy Roofing/Siding 12 08-17-2008 05:38 PM
bending shingles farrington135 Roofing/Siding 2 06-09-2007 11:40 AM
Trimming shingles sedwick Roofing/Siding 7 06-07-2006 12:11 AM
