-   -   Trimming shingles on rake edges (http://www.diychatroom.com/f9/trimming-shingles-rake-edges-10477/)
sandyman720 08-06-2007 08:52 PM
What is the best way to trim shingles on the rake edges after installation?
Malcolm 08-06-2007 09:01 PM
If the tiles are hot, you can trim them with a roofing hook blade and a straight edge pretty easy. I just used my metal cutting shears. It came out clean.
Ed the Roofer 08-07-2007 09:16 AM
Malcolms answer is right on the mark.
Ed
FatAugie 08-30-2007 05:35 PM
What if they're cold (i.e. sun behind clouds, temp in lower 70's)?
Trying to cut Timberline Ultras is next to impossible.
Malcolm 08-30-2007 05:40 PM
Use shears.
FatAugie 08-30-2007 06:02 PM
Originally Posted by Malcolm (Post 60548)
Use shears.
You mean like Tin snips?
Malcolm 08-30-2007 06:49 PM
Metal shears like these. I guess people call them tin snips. When I hear tin snips, I think of small aviation snips. Snap a chalk line and use these. you will come out with a smooth rake.
http://malco.malcoproducts.com/produ...m12a_mc12a.jpg
Clutchcargo 08-30-2007 06:50 PM
63 Attachment(s)
Do you normally trim the shingles after installation?
FatAugie 08-30-2007 06:57 PM
Yeah, that's the kind I have (small aviation tin snips) and they weren't working for sh#t. I'll have a pair of these by noon tomorrow!
:thumbsup:
Crackers 08-30-2007 07:30 PM
I shoudl have read this yesterday!!!
I used a circular saw. It made a mess. Jig saw worked well, but still not perfectly straight. I am kind of p*(ssed off now, your experience rules.
FatAugie 09-01-2007 07:35 AM
You're right, they work great.
Also, I found that if I started at the bottom and worked up, it was a hell of a lot easier to trim straight.
Thanks everyone!
the roofing god 09-01-2007 11:29 PM
usually use a hook blade and cut every 5 as their installed using a full shingle as an edge(line),you should only cut thru 1 thickness and make a 2nd pass on double piece areas,if you`re using snips,install a soldier course,flip the shingle upside down in place,mark it, cut it and nail it in place as finished item:thumbsup:
FatAugie 09-02-2007 08:19 AM
what's a soldier course?
the roofing god 09-02-2007 01:23 PM
it`s a shingle you install going vertical up the rake eave(side),say it`s 12"high shingle,you snap a line at 11" so the shingle overhangs 1" to set your overhang you nail it tight to the roof edge and it also adds strength against blow-offs
the roofing god 09-02-2007 01:24 PM
also for marking upside down would be w/granule side up!
