Trimming Off Rotten Bottom Of T1-11: Edges? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-01-2013, 10:45 AM   #1
Rewards Points: 12
Trimming off rotten bottom of T1-11: edges?
Hi all,
I've got a bit of rot creeping up the bottom of some T1-11 siding; I'm thinking of trimming about 6" off the bottom with a Skil saw, setting the depth to the depth of the plywood and pulling off, then replacing it with strips of Smartside or some of that vinyl decking "lumber".
The house, though, is built into a hillside, so there are lots of "steps" along the foundation. I've also got (unrotted) wooden corners on the house that are in great shape and would be a major pain to cut through or remove. The siding runs underneath these corners, so I'd need to cut down alongside them.
So I can cut a long horizontal line with the Skil saw, but what do I do about the last several inches leading up to the corners and where the foundation "steps" up? The Skil saw doesn't reach the edges due to its base and the fact that it's a round blade. A jigsaw or recip saw requires depth, which I don't have.
I have a Dremel -- is there a tiny wood bit that might take me through these last few inches, and down the side by the corners?
PantsMasterson is offline   Reply With Quote
Old 09-01-2013, 11:25 AM   #2
Rewards Points: 222
i am going to say = we need pics.
Fix'n it is offline   Reply With Quote
Old 09-01-2013, 12:19 PM   #3
Rewards Points: 12
Here goes: one of these shows a corner, the other a point where the foundation "steps up". The reason that the siding is darker at the bottom is that it was covered until recently by 1x3 -- an early, less smart attempt at protecting the bottom of the siding from water.
Old 09-01-2013, 01:13 PM   #4
Rewards Points: 13,300
Why is that flashing there? It's just acting like a funnel to get the right to the T-111.
Yes cutting it out and replacing with vinyl lumber will work but you need to also seal the end grain of the siding and add strips of Z molding up under the siding and out over the new vinyl to divert water away.
Ya I see that strip of 1 X all the time at the bottoms of walls.
It's 100% sure going to help rot out the siding every time.
Once again the basic building 101 rule of keeping any siding at least 6" away from any solid surface or grade was not followed. Now you can see why it's now code.
Old 09-01-2013, 01:24 PM   #5
Rewards Points: 12
That's good advice, but the question I'm asking is how to trim the bottom of this siding to the edges of things like the steps and the corners. I'm aware of the problems it's causing.
What I need to know is how to cover the distance from the what the Skil saw can cut to the corners/sides, so I can remove the bottom part of the siding and take steps.
Old 09-01-2013, 04:13 PM   #6
Metal Roofing
Rewards Points: 600
It could be cut and patched with new siding, but it would look like a patch job. I think you need to look for a solution, like Joe mentioned you need 6" of clearance or your just going to have splashing water rot the replaced portions again.
We only have a small pic to go by, how tall is this wall, is it just this location on the house or do you multiple areas like this?
A pic from further back would help. Without seeing the whole picture, i would want to change the entire sheet or sheets of siding and change the detail on the bottom to give me the clearence i needed.
Make sure you have gutters on this area of the house, all the water splashing isnt gonna help your problem.
AndyWRS is offline   Reply With Quote
Old 09-01-2013, 06:56 PM   #7
What the ciruler saw will not cut an oscillating saw will.
I would just cut right through the outside corners at the bottom and ether do not reinstall them and just band the outside with the PVC lumber or replace the lower part with 1 X 4 vinyl.
The outside corner trim is often the first place to start rotting because no one seals the cut or installs it in direct contact with a solid surface, trapping in moisture.
Old 09-02-2013, 09:04 AM   #8
Rewards Points: 12
One of the issues with the house is that it was built (it seems) to be bricked, but then they half-assed the job, which is why there's this weird extended flashing around the bottom -- I can't leave 6" of clearance, because the foundation itself forms a lip that water will splash up off of. The best I can do is have flashing that (when I did it, which wasn't super smart in retrospect) covers the lip of the foundation, goes down outside the foundation and up behind the siding.
I'm going to trim the siding higher, though, so there's no standing water against the bottom of the siding this time around. There's no getting around the lip, though.
I'll probably take joecaption's advice re. cutting through the corners. Picked up an oscillating saw yesterday. Today, of course, it's pouring rain...
I've looked for Z flashing at three different hardware/reno stores here (Sherbrooke, Quebec) and only get blank stares. I may start a thread asking where I can find the stuff.
Old 05-15-2014, 03:07 PM   #9
Rewards Points: 12
Bringing back an old thread here..
I have the same problem with my T1-11. Goes down all the way to the cement on the North side of the house, so it gets splashed and sun never hits it to dry.
I have never replaced siding but I was thinking about cutting the rotted area away, using a Z-flash, and replacing the removed T1-11 with some hardi vertical siding. It won't look perfect but it'll look better than using horizontal siding. Another option is to just replace it with more T1-11 and pressure wash it once a year.
Any thoughts?
On a side question, how hard is it to replace T1-11? I've never attempted it but it doesn't seem too tough..
leonuug is offline   Reply With Quote
Old 05-15-2014, 03:49 PM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,972
Not hard.
Just important to flash and step the details correctly.
Tags
cutting , plywood , skilsaw
Trimming bottom of cultured stone J.P.R. Concrete, Stone & Masonry 1 11-02-2012 09:39 PM
Bottom Plate for Stud Wall svaic00 Building & Construction 3 07-10-2012 03:07 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
Replacing window sash with rotten bottom jandrew Carpentry 3 08-31-2008 05:02 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
