Treehouse Roof Coating - 2/12 Flat Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-11-2011, 11:41 AM   #16
Originally Posted by jjangell View Post
I ended up using a paint on roofing system from Gaco http://www.gacoretail.com/gacoroof.html
The roof is holding up well...My issue that I need a solve for is the area around the tree penetration. The water rolls off of the roof into the treehouse and the water runs down the tree and end up on the floor of the Treehouse.
Use step flashings to make a collar some 4-5" away from the tree. Then overlay the top half with bituthene. Then wrap a flexible booty (truck tire innertube) around the tree & over the step flashing.
Treehouse Guy is offline   Reply With Quote
Old 02-11-2011, 11:47 AM   #17
Rewards Points: 16
Excellent Suggestion - How Do you suggest fastening the flexible booty to the tree and to the flashing?
jjangell is offline   Reply With Quote
Old 02-11-2011, 11:52 AM   #18
let it flop over the flashing. Use bungee cord or a few small nails at the tree, plus 3 tubes of caulk if desired!
Old 02-11-2011, 11:54 AM   #19
Rewards Points: 16
I like the bungee cord!
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 06:08 AM
