#1 |
Treehouse Roof Coating - 2/12 flat roof
I'm building a treehouse for my son in our Backyard.
I am going to use standard 3/4 plywood for the roof and would use a suggestion as to what I might coat the roof with to assist in standing up to the rain etc... I do not want to spend a fortune on this...Would appreciate any and all suggestions. Last edited by jjangell; 11-11-2009 at 10:30 PM. |
#2 |
I would use a peel and stick granulated cap sheet(sbs).You could also use ice and water shield and then shingle it.For that matter you could just double up 30#felt and shingle it,I mean it is just a treehouse.
#3 |
Can I shingle a 2/12 front is seven feet back is five feet. Did not think I would shed water and every dry out
#4 |
I think you would be fine.If you used ice and water under shingles,it would never leak,but if your on a budget I would use 30#.I wouldn't do it on a house,but it is a treehouse.
#5 |
If your really worried about it use peel and stick sbs. http://www.certainteed.com/products/...adhered/308491
#6 |
My uncle used to put roll roofing on his garage. It's like asphalt shingles, but in the form of a roll, like felt. You just nail it down and put roofing patch on the nail heads.
I made a dog house about a decade ago and got a piece of corrugated metal roofing and screwed it on with decking screws. It's almost totally flat, and it seem to be holding up. I put liquid nails on the screw heads and painted it all with house paint. |
#7 |
The metal roof is appealing...But unfortunately the treehouse is within earshot of our bedroom and I can't imagine that I would be thrilled with that roof in the rain.
#8 |
Moderator
Be careful of your roof size, including overhangs: One-story detached accessory buildings used for greenhouse, tool or storage shed, playhouse or similar uses, provided:
1. The projected roof area does not exceed 120 square feet; and 2. The building is not placed on a concrete foundation other than a slab on grade. From: http://www.seattle.gov/dpd/Permits/F...sp#questionone And the side variance may be 3' to roof, check it out or an upset neighbor could report it and you tear it down or shorten the roof. Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#9 | |
Treehouse Roof Coating - 2/12 flat roofQuote:
Thanks for the information...You certainly know your stuff...I do appreciate it. Do you work in construction in Seattle? |
#10 |
Treehouse Roof Coating - 2/12 flat roofPHP Code:
#11 |
Moderator
No, I'm in Tacoma. With the home building economy as such, the City and County are looking for untapped sources of revenue......
Be safe, Gary
#12 | |
#13 | |
My shed has metal roofing over open purlins and I don't really hear it unless I'm standing inside it. Even then it's only a certain type of rain -- large drops with space between them, if you know what I mean... We put metal on the house and if you stop and think about it you might be able to tell that it sounds different when it's raining, but it's not the kind of thing that you actually hear (like a truck driving past, or a dog barking). |
#14 | |
I would use bituthene and drive some capnails around the border and leave it at that. If you have money for shingles, it will last longer and be more durable, but the above will keep water out on it's own for years. I have also built a couple Ondura roof treehouses and that is relatively cheap and people like it. It comes in 8 colors. Here's the Ondura website. |
#15 | |
The roof is holding up well...My issue that I need a solve for is the area around the tree penetration. The water rolls off of the roof into the treehouse and the water runs down the tree and end up on the floor of the Treehouse. ![]()
| Display Modes | |
| Flat roof questions, advice, ballpark estimate | JerryH | Roofing/Siding | 18 | 11-07-2008 05:08 PM |
| Flat roof - Rolled? - leaks Advice? | JJ2001 | Roofing/Siding | 4 | 11-19-2006 07:17 AM |
| Reflective Coating on Flat Roof | MelindaA | Roofing/Siding | 3 | 01-05-2006 06:08 AM |
