Translation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-29-2012, 10:34 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
Translation
GAF BUILT-UP ROOFING SYSTEM. ICBO REPORT NO.
ESR-1274. HOTMOP TOP LAYER OF FIBERGLASS CAP
SHEET EMBEDDED INTO HOT ASPHALT APPLIED AT 30
LBS. PER 100 SQ. FT. OVER 2 - LAYERS OF FIBERGLASS
PLY SHEET EMBEDDED INTO HOT ASPHALT APPLIED AT
25 LBS. PER 100 SQ. FT. OVER 1 - LAYER OF SECURELY
NAILED DOWN FIBERGLASS BASE SHEET. ALL ROOF
RELATED METALS TO BE MIN. 26 GA. GI OR ZINC
ALUME.
This is the construction note for the 1.9:12 slope on part of my new roof.
Can someone put this in terms I can understand?
ddawg16 is online now   Reply With Quote
Old 04-30-2012, 11:24 PM   #2
This is the type of materials he's using, and the order he's using them in.
roofwalker913 is offline   Reply With Quote
Old 05-01-2012, 11:50 AM   #3
Doing This Way Too Long
Rewards Points: 532
Standard application of a 2-ply and a cap over a nailed base sheet. Installed properly, it's been a decent system for a hundred years.
They are going to nail down a 40mil base sheet to your decking, mop two layers of fiberglass mat, then mop a cap sheet (90mil to 160mil depending on mfr) over the top of that.
OldNBroken is offline   Reply With Quote
switch to garbage disposal question tard01 Electrical 64 03-30-2012 05:19 PM
Deck development regulations translation drtbk4ever General DIY Discussions 3 07-12-2009 08:26 AM
best bed for cobblestone driveway? danlauter Building & Construction 9 04-09-2009 09:37 AM
Us / Brit translation - a little help here? hedgewizard Building & Construction 6 06-10-2008 01:39 PM
