Transitioning Siding On Different Planes? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-22-2014, 12:17 PM   #1
Rewards Points: 117
Transitioning Siding on Different Planes?
I'm wanting to side about 3' of exposed basement wall on our house to meet up with the existing siding that stops where the sill plate is. The problem I'm having is if I fur the block wall out, even using 1" material, I will have a joint that has the existing siding meeting the new siding on two different planes (see my illustration below) Green block would represent a furring strip:
My question is this. What do I have as options for this transition point? I thought about furring the existing edge (bottom edge of existing siding), but encasing that furring strip in white aluminum (I have a brake) and then attaching J-channel to it's face to match the edging of the bottom, but it's still going to look "kicked out."
I'm a bit at a loss here. Thoughts?
mgh-pa is offline   Reply With Quote
Old 04-22-2014, 04:07 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 850
Counter flash in aluminum out of the same color the siding is.
It won't look very correct though.
Old 04-22-2014, 05:52 PM   #3
Rewards Points: 12,802
Space the wall out with blue foam.
It will increase the R value and come out flat.
Old 04-22-2014, 06:07 PM   #4
kwikfishron's Avatar
Rewards Points: 84
You could add a properly flashed trim detail there to make the transition. A 2" sloped shelf or maybe a belly-band, hard to say what would look good without seeing the actual wall.
kwikfishron is offline   Reply With Quote
Old 04-23-2014, 07:29 AM   #5
Rewards Points: 117
I'll get a picture this afternoon.
Joe, unless I'm missing something, blue foam would still kick out the wall the thickness of the foam, correct? Right now, the face of the block wall is even with the sheathing above (obviously). So the thickness of the siding is all the difference there is between planes. Once I add foam or furring to the bottom wall, I will have exaggerated that distance even more.
Old 04-23-2014, 09:06 AM   #6
Rewards Points: 94
It will be kicked out some whatever you put on underneath, fact of life in this situation. So if your choice is to add to the. Concrete, choices are to try to fir out the bottom of existing to make it somewhat gradual to use the suggested detail approach. A third would be just to side to the concrete since it is totally for appearances. Since it sounds as if you are vinyl, just use 1 1/4" tapcons instead of nails. That said, easier with a picture. Ron
ront02769 is offline   Reply With Quote
Old 04-23-2014, 09:23 AM   #7
Rewards Points: 117
I was unaware you could attach vinyl directly to concrete. Although the price in tapcons itself my be a bit prohibitive in itself. Thanks for all of the suggestions. Again, pictures to come this afternoon.
Old 04-23-2014, 08:23 PM   #8
Rewards Points: 117
Here you go:
Old 04-24-2014, 03:31 PM   #9
Low Slope Roofing
Rewards Points: 114
Use 1/4" or 1/2" lath and short nails.
1985gt is offline   Reply With Quote
Old 05-15-2014, 08:54 AM   #10
Rewards Points: 117
So I've been giving this some thought. Since it's such a small section of wall/siding needed. Can I just attach the vinyl directly to the block wall? I could either use anchors/screws, or a flat head tapcon. Any reason NOT to do this?
Old 05-15-2014, 11:10 AM   #11
Rewards Points: 850
Besides the difficultly of it and punching a bunch of holes in the block, it is doable.
How to Nail New Siding Under Existing Siding Shuriko Building & Construction 25 05-21-2012 09:33 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
