Transition Sloped Metal To Flat Epdm - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-04-2012, 11:01 PM   #1
Transition Sloped Metal to Flat Epdm
What is the best method to make a transition from a 6/12 metal roof to a 2/12 EPDM roof section?
iplay1515 is offline   Reply With Quote
Old 10-04-2012, 11:51 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 382
Does the metal roof overlap the EPDM or does it just butt? Is this a reroof or existing?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-05-2012, 05:50 AM   #3
This is a re-roof of an existing shingle and epdm roof. The metal will overlap the epdm and will cover the shingles. 1x4 strips will be attached to the existing shingle roof first.
The shingle part of the roof is on the upper elevation and currently makes a transition to epdm at the lower elevation as the roof slope flattens over a screen porch on the rear side of the home.
Neither the epdm nor the shingles are leaking, and the epdm section is less than 7 years old. However, the shingle section is much older, has cosmetic issues, and will soon need replacement.
Old 10-05-2012, 06:33 AM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Me, I'd add a 4-5' piece of .060 reinforeced EPDm at the transition and run it about 3' up the shingled area after removing the shingles, and after folding all the metal ends so there are no sharp edges, I'd start the panels at least 1' up from the break.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Windows on Wash (10-05-2012)
Old 10-05-2012, 06:49 AM   #5
Rewards Points: 13,694
I would never install the 1 X 4's over an existing shingled roof. No way to know where your attaching them.
But ha that's just me.
Might want to check out the manufacturer of the roofing to see what they suggest.
Old 10-05-2012, 08:35 AM   #6
I plan on attaching the 1x4 strips to the rafters which are consistently 16" oc.
Old 10-05-2012, 08:38 AM   #7
Thanks.
I don't understand starting the panels 1' UP from the break. It seems like the panels should overlap the break and start 1' DOWN from the brake. What am I missing?
Old 10-05-2012, 01:22 PM   #8
Pro Slate Roofer
tinner666's Avatar
When the roof gets damaged or worn at teh break, how do you propose to repair it later? You'll have a cleaner roof and a repairable roof if you start the metal 1' above the break/transition.
Pix of EPDM and slate. No metal ones to show, but this is how you want to do it.
Transition Sloped Metal to Flat Epdm-small-epdm-job-5-.jpg   Transition Sloped Metal to Flat Epdm-small-epdm-job-2-.jpg   Transition Sloped Metal to Flat Epdm-after-slate-4-.jpg   Transition Sloped Metal to Flat Epdm-epdm-termination-cover.jpg
Old 10-05-2012, 02:32 PM   #9
Thanks. Nothing quite like a few photos to help clarify.
EPDM vs Modified Bitumen for flat roof arubatan Roofing/Siding 16 11-19-2008 06:50 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 08:41 AM
flat epdm roof problem larry42 Roofing/Siding 5 04-28-2007 10:03 PM
