Transition Seam - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-14-2010, 06:01 PM   #1
Solutions (handyman)
Rewards Points: 364
Transition seam
What is recommended along the seam between two different roof pitches? Such as where a porch roof of a low pitch meets with a higher house pitch. I believe there should be something at the transition seam under the shingles (Regular Asphalt). Metal Flashing? Some other sub surface?
Thanks.
Mark Harvey is offline   Reply With Quote
Old 03-15-2010, 10:15 AM   #2
Commercial Roofing
AaronB's Avatar
I recommend an ice barrier, situated to drain ON TOP of the lower section, and a metal flashing, also situated to drain ON TOP of the lower section.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
The Following User Says Thank You to AaronB For This Useful Post:
Mark Harvey (03-15-2010)
Old 03-19-2010, 11:56 AM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Thanks.
Are both the roof planes asphalt shingles?
seeyou is offline   Reply With Quote
Old 03-19-2010, 04:38 PM   #4
Commercial Roofing
AaronB's Avatar
Better response than mine...
Old 03-20-2010, 10:56 AM   #5
Rewards Points: 364
Yes to both roofs being asphalt shingles.
Old 03-20-2010, 11:45 AM   #6
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I would install I&WS so it laps over a course of shingles in the lower pitch plane a course or two below the transition and just shingle through the transition. If you add metal, you've created an unsealed seam where water can back up under the flashing. It looks good on paper, but doesn't work that well in practice, especially in heavy snow country.
I've stopped leaks in this detail several times by removing the metal and shingling as described above.
The Following User Says Thank You to seeyou For This Useful Post:
Mark Harvey (03-20-2010)
Carpet Seam help Goldglv Flooring 6 02-01-2010 07:30 AM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 12:12 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
Drywall Mudding Challenge: Seam vs. Tapered Corner cjakins Drywall & Plaster 3 03-10-2009 12:41 PM
1.75" room / floor transition MrLinux Flooring 1 03-11-2008 02:19 PM
