Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-20-2007, 06:54 PM   #1
torchon roof doesn't seem solid
I have a torchon flat roof on part of my house (13 years old, designed by an architect--so it is really a fiddly design and very high maintenance--I'll never do that again!) and there has been some leakage through the floor below so I dragged up the decking over the membrane and it seems as if the membrane is still intact, but it feels like it is solid underfoot in some places and squishy other places--is that normal, as you supposed to put decking over it and not walk on it direct, or is there a suspicion that water has got in rotting the roof underneath. There is no leakage in the middle of the ceiling below, just on the edges, as the roof is not completely flat and water tends to pool on the very edges above the guttering.
so how squishy should it be?
Thanks, guys. I am learning to do this on my own and sometimes the books don't tell you what you need to know.
algernon is offline   Reply With Quote
Old 02-20-2007, 11:01 PM   #2
Commercial Roofing
AaronB's Avatar
Yeah, squishy wood decking is a definite symptom of a leaky roof. A leaky roof is by no means the only cause, but the most common.
The flat roof may not be a bad design, but a deck on top of it tends to hurt worse.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
flat roof leak snikda9 Roofing 16 01-26-2006 05:25 PM
Need Help on the Flat Roof and more... MelindaA Roofing 12 12-21-2005 11:12 PM
