Torching Part Of Shingle Based Roof At Hog Valley - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-10-2012, 02:07 AM   #1
Rewards Points: 366
Torching part of shingle based roof at hog valley
I came across this thread about torching...
Torch Down vs. Cold Process
and was wondering if there's any issues and concern for torching applied to a hog valley for shingle roof. This is what the roof contractor specified in his bid for new shingle roof (to replace improperly done roof):
(5) Properly install and nail into place one layer of premium fire-resistant fiberglass base sheeting over the cleaned and prepared substrate of the low-sloped ‘hog valley’ between adjoining roof slopes over right side of home per all mfg. specifications, relevant building codes and best industry practices.
(6) Properly install and torch into place a rolled asphalt-composition, rubberized modified-bitumen ‘smooth’ membrane over the newly applied fiberglass base sheet and roof substrate of the low-sloped ‘hog valley’ per all mfg. specifications, relevant building codes and best industry practices.
(7) Properly install and torch into place a rolled asphalt-composition, granulated-surfaced ‘Capsheet’ membrane over the newly applied ‘smooth’ membrane. The color of the surface-granulated ‘Capsheet’ roof membrane will be matched as closely as possible with the pitched shingle roof system.
daluu is offline   Reply With Quote
Old 09-11-2012, 01:09 AM   #2
Rewards Points: 324
Without pics, its hard to say, but we often use torch-down on internal gutters between roofs, and flat areas at the top of roofs that have been put there because of height restrictions, without problems. Only issue i've had is the limited range of colours held in stock here by the suppliers.
mgp roofing is offline   Reply With Quote
Old 09-11-2012, 08:48 AM   #3
Rewards Points: 83
A 3 part membrane, nice.
We always torch dead valleys and such.
bcdemon is offline   Reply With Quote
Old 09-11-2012, 02:19 PM   #4
Rewards Points: 366
Here's a pic for reference. I believe this was the area in question. This is a photo from roof inspection report:
https://www.dropbox.com/s/073r6sjg1r1bu5c/hogValley.jpg
Old 09-11-2012, 06:50 PM   #5
Rewards Points: 83
Going by the way it was shingled, this is how the slopes look to me, is this correct?
It's hard to judge by the photo.
Old 09-11-2012, 07:27 PM   #6
Rewards Points: 366
yes, that's correct how the slopes flow.
metal roof over asphalt shingle roof ozom Roofing/Siding 14 06-11-2012 08:46 PM
Roof coating for asphalt shingle roof? downunder Roofing/Siding 13 04-03-2011 10:03 AM
Metal roof vs asphalt shingle roof Bob_T Roofing/Siding 1 06-20-2009 06:51 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Insulating under part of my Flat Roof Hushpuppy Roofing/Siding 5 02-13-2006 03:45 PM
