Torching A New Cap Sheet To An Old Cap Sheet - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-27-2009, 07:35 PM   #1
Cool
torching a new cap sheet to an old cap sheet
I got a ten yr old GAF Rubber Roid granulated cap sheet over my shop. Took some hail damage. Roofers are going to torch a new granulated cap sheet to the old. I wanted the old surface blown clean then primered. They don't think they need to primer. Should they are not ??
taeroof is offline   Reply With Quote
Old 05-27-2009, 09:54 PM   #2
Yes at the very least you need primer.Degranulating is always better,but more time consuming.Before priming it should be thoroughly cleaned.If they are not priming the membrane will only be stuck on the laps.Phone the manufacturer or a qualified roofer and get there opinion as well.
johnk is offline   Reply With Quote
Tags
cap sheet , granulated , primer , torch down
seal seams on self sick tiles NoExperience Flooring 3 08-12-2008 07:25 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
