Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-04-2013, 05:55 PM   #1
Torchdown roof repair around skylight
Hello, I'm planning on installing a skylight on my house, which has a torchdown roof. The skylight install part i'm good on, but does anyone have any advice on what to do once it's in? Do I just need to seal the edges (where the flashing meets or goes under the existing roof with roofing cement? (i'm guessing that it can't be that easy) Or do I need to apply new torchdown material over the flashing? If it's the latter I'm guessing I'll have to hire it out (not interested in learning how to torchdown a roof [or possibly torching my roof] for this relatively tiny repair (or is it worth it?)...
thanks!
stencil is offline   Reply With Quote
Old 02-04-2013, 09:14 PM   #2
Metal Roofing
You answered your own question, you will need to have it torched. I would go with a curb mount skylight.
AndyWRS is offline   Reply With Quote
Old 02-05-2013, 08:34 AM   #3
Roofmaster
Slope of the roof?
Size of the skylight?
Type of Mod Bit? (SBS or APP) Granular surfaced or smooth? Coated?
Is the skylight curb welded water tight?
On a low slope roof the curb must be at least 8 inches high. You cannot use a low profile skylight on a low slope roof.
" A lot of men build things, and a lot of things fall down "
Low slope roof repair Aarone1972 Roofing 5 02-02-2012 04:22 PM
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
1'X20' flat roof repair hohadcr Roofing 2 08-26-2009 12:17 AM
My roof is sagging - Correct Course of Correct Repair? young-jennifer Building & Construction 5 12-15-2008 08:59 PM
Metal Roof Repair Questions bruce3404@hotmail.com Roofing 3 09-17-2008 11:00 PM
