Torchdown roof repair around skylight
Hello, I'm planning on installing a skylight on my house, which has a torchdown roof. The skylight install part i'm good on, but does anyone have any advice on what to do once it's in? Do I just need to seal the edges (where the flashing meets or goes under the existing roof with roofing cement? (i'm guessing that it can't be that easy) Or do I need to apply new torchdown material over the flashing? If it's the latter I'm guessing I'll have to hire it out (not interested in learning how to torchdown a roof [or possibly torching my roof] for this relatively tiny repair (or is it worth it?)...
thanks! |
You answered your own question, you will need to have it torched. I would go with a curb mount skylight. |
Slope of the roof?
Size of the skylight? Type of Mod Bit? (SBS or APP) Granular surfaced or smooth? Coated? Is the skylight curb welded water tight? On a low slope roof the curb must be at least 8 inches high. You cannot use a low profile skylight on a low slope roof. |
| All times are GMT -4. The time now is 11:28 PM. |
