Torch On Round Pipe - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-08-2015, 05:28 PM   #1
Torch on round pipe
Hi I'm currently looking into refelting my roof I'm a little unsure how I go around the flue pipes I have coming out the flat roof, is there a correct method on how to felt round them
Richard1972 is offline   Reply With Quote
Old 10-08-2015, 06:25 PM   #2
craig11152's Avatar
Rewards Points: 1,950
Torch on round pipe
There are a couple flat roof experts that should show up and give you guidance.
But "refelting your roof" ain't gonna fly in here.
They will want specifics on what type of system you are installing.
Finally, he switched to a bone saw to finish the job, and at 9:17 p.m., Mountain time, the head of the greatest hitter who ever lived had been sliced off.
craig11152 is offline   Reply With Quote
Old 10-09-2015, 01:40 AM   #3
Torch on round pipe
Hi Craig thanks for your reply it's only my extension roof 12ftx18ft the felt is ripped in sections so just looking to replace it,I I will be using a 3 layer torch on finished in a sbs mineral
Old 10-09-2015, 08:30 AM   #4
Low Slope Roofing
Rewards Points: 114
Torch on round pipe
Have you ever done torch down roofing before? If the answer is no then I highly highly highly recommend if torch down is the way you want to go to hire a professional. There are other methods that are far less risky then a untrained person with a torch, you can achieve the same or better results using a cold process method either with adhesives or with the self adhered sheets.
1985gt is offline   Reply With Quote
Old 10-09-2015, 08:39 AM   #5
Torch on round pipe
Hi yes I've used the 3 layer before on my garage,it's just the pipes I'm unsure about, I've uploaded a photo of garage
Old 10-09-2015, 09:08 AM   #6
Low Slope Roofing
Rewards Points: 114
Torch on round pipe
So you will be nailing a base, torching a base and then torching a cap sheet? Have a picture of the area? I'm assuming your going to tear off the existing?
Old 10-09-2015, 09:13 AM   #7
Torch on round pipe
Yes stripping the existing down to the boarding and yes tacking 1st ,burning the 2nd underlay then going over with the burnt mineral
Old 10-09-2015, 09:22 AM   #8
Low Slope Roofing
Rewards Points: 114
Torch on round pipe
It depends on where the sheet lands, say the sheet lands 6" from the lap, you would simply cut up through the lap, precutting may help. If it lands 1/2 way though the roll you can either cut up or down or split the roll. By that when you get to the pipe, cut the sheet so it goes around the pipe, torch it down. Now when you restart the sheet it will lap over it in that area. What ever you do for the mid ply do the opposite for the cap sheet, or at least try. then when that's all done you install your lead and targets.
The Following User Says Thank You to 1985gt For This Useful Post:
craig11152 (10-09-2015)
Old 10-09-2015, 09:52 AM   #9
craig11152's Avatar
Torch on round pipe
they say a smiley is worth a thousand words.
The Following 2 Users Say Thank You to craig11152 For This Useful Post:
1985gt (10-09-2015), ron45 (10-09-2015)
Old 10-09-2015, 10:00 AM   #10
Torch on round pipe
Lol that's worse case scenario
Old 10-09-2015, 10:31 AM   #11
Low Slope Roofing
Rewards Points: 114
Torch on round pipe
There is a reason why some roofers do not do torch downs any more. There is far better ways to accomplish the same thing with out the possibility of burning the house/building down.
ron45 (10-09-2015)
Old 10-09-2015, 10:41 AM   #12
Torch on round pipe
Epdm is a possibility
Old 10-09-2015, 01:17 PM   #13
Low Slope Roofing
Rewards Points: 114
Torch on round pipe
Any slope to the structure?
Old 10-09-2015, 02:02 PM   #14
Rewards Points: 4,573
Torch on round pipe
Adding to gt's comment.
That and insurance.
ron45 is offline   Reply With Quote
Old 10-09-2015, 02:31 PM   #15
Torch on round pipe
Yes slopes so will be putting drip formers into the gutter
Soldering a leaky pipe WyrTwister Plumbing 14 02-15-2014 06:57 PM
pvc drain pipe in concrete debiasio Plumbing 8 12-06-2013 11:31 PM
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 09:00 AM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 01:49 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
