Torch Down Roofs - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-18-2008, 10:33 AM   #1
torch down roofs
I want to take off an existing torch down roof and redo it . How do you remove existing roofing?. Its still pretty solid in alot of places , do I need to heat it again to take it off .do you tear off to the base layer and then it comes off easily at that point..
motorhome6 is offline   Reply With Quote
Old 11-18-2008, 05:13 PM   #2
Slice it with a sharp utility knife, using a hook blade and then use a roofers tear-off shovel or pitch fork to get under it and roll it progressively back onto itself in manageable sized sections.
Most times, unless there is decking damage, you would not need to remove the material if it is one layer thick.
Ed
Ed the Roofer is offline   Reply With Quote
Old 11-19-2008, 04:10 PM   #3
Doing This Way Too Long
Rewards Points: 532
Ed
Unless it's a mobile home, only allowed one layer.
OldNBroken is offline   Reply With Quote
Old 11-23-2008, 11:32 AM   #4
Commercial Roofing
AaronB's Avatar
Polyurea is the way to go for mobile homes, if it is a mobile home.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Torch down info sjacobso Roofing/Siding 8 07-24-2012 03:54 PM
Questions about torch down bitumen and epdm rubber? Max1119 Roofing/Siding 1 08-11-2008 11:46 PM
Coating over torch down before new decking bobhpete Roofing/Siding 2 05-17-2008 09:39 PM
rubber or torch jcd34 Roofing/Siding 2 08-06-2007 07:46 PM
replace tar & gravel roof with shingles & torch down rt1035 Roofing/Siding 4 12-17-2005 06:39 PM
