Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 07-11-2011, 09:54 AM   #1
Torch down roofing.
What materials are needed for torch down and what are the steps?
bammbamm is offline   Reply With Quote
Old 07-11-2011, 11:27 AM   #2
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Torch down roofing.
Seriously? Is this Bamm Bamm from CT?
If you've never done torch down modified bitumen, I would not suggest trying it. Burning down a building would be no fun. You would need a cover board to install over the substrate, perhaps a 1/2" high density fiberboard. Then a base sheet of some kind, usually a 33# fiberglass or 43# organic. Base sheet can be doubled up for higher system rating. A smooth modified bitumen can be installed for a 10 year system, or 12 year if coated. Or a granulated cap can be installed for a 15 year system. Granulated requires more work, imbedding the seams and penetrations, forget to imbed and it will fail. If smooth and granulated are used together, it will be a 20 year rated roof.
Why not try something easier and safer like EPDM or TPO?
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 07-11-2011, 11:28 AM   #3
Grumpy's Avatar
Torch down roofing.
a materials list for modified bitumwn owuld include base sheet, fasteners, mid ply, cap sheet, primer, various metal flashings, caulking etc...
-Grumpy
Old 07-12-2011, 09:15 AM   #4
Torch down roofing.
Insurance
shazapple is offline   Reply With Quote
The Following User Says Thank You to shazapple For This Useful Post:
Grumpy (07-12-2011)
Torch down roofing question Z-man Roofing/Siding 14 10-06-2012 12:21 AM
Tying in Torch down Roofing to EPDM Sherryfr Roofing/Siding 6 04-06-2011 10:14 PM
Torch on roofing question/advice bikeboy Building & Construction 2 03-11-2010 03:33 PM
torch on roofing rosemaryaclark General Discussion 3 10-21-2009 12:28 PM
Torch on roofing 5.0roofer Roofing/Siding 1 10-05-2007 01:09 AM
