Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-10-2009, 07:17 PM   #1
Default Torch down roof without base layer?
I have framed up my 16x12' manshed in the backyard. Essentially a place to hang out in. It has 2x6 rafters on 16" OC with a 2/12 pitch. Basically a shed style "flat" roof with the front wall 10 feet and the back wall 8 feet.
Wanted to contract the roofing. A roofing contractor has looked at it and has recommended a torch down roof due to the low pitch. However, he says he wants to torch it down directly to the osb decking. He says adding the base layer makes it more wind prone. He says when it comes time to replace the roof you can just torch down another roof over the old one.
It's just a small building and I don't want to over think it, but does this sound OK?
66merc is offline   Reply With Quote
Old 06-10-2009, 07:25 PM   #2
Here is a link with photos if it helps.
http://s155.photobucket.com/albums/s...mmeup/Manshed/
Old 06-11-2009, 02:24 AM   #3
I wouldn't recommend torching right to the deck.I would at the very least put a nailed base sheet on.I don't see how your roofer feels an added layer makes it more 'wind prone'.That would mean every properly installed torch on roof is gonna blow off.Go with a base,if he doesn't want to do it,find someone who will.Alot of people hungry for work.Just my 2-cents
johnk is offline   Reply With Quote
Old 06-11-2009, 02:31 AM   #4
Super Moderator
You should use a proper base sheet, #43 pound fiberglass is what it is commonly called at the supply houses, but then the roofer needs to nail it in place with large round metal cap nails to hold it in place, which is very common to do.
Also, if there is a fascia board on all 4 sides, then a method to ensure that none of the edges ever get caught by wind and lift up and also to not have to be concerned if the modified bitumen material will remain bonded to the edge sheet metal flashing, you could direct him to use an aluminum termination bar, with oval slots to install wood-tec screws through and space the screws every 6" to 12" On Center, all the way around the perimeter edges.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-11-2009, 02:48 AM   #5
Old 06-11-2009, 03:55 AM   #6
Super Moderator
And I agree with John, wholeheartedly on that point, LOL.
Ed
(Don't worry, thats not my ego talking. I was just having a little fun)
Old 06-11-2009, 09:40 AM   #7
Residential Roofer
Slyfox's Avatar
One of my former employees back in 98 burnt his non attached 2 car garage up pretty bad after borrowing my torch and propane tanks simply because he saved $305.00 bucks by skipping the base sheet and metal eave/rake flashing's.
He had to replace portions of both the right side and back wall, plus several deck studs and ply wood.
In 92, a crew torching down a cricket in Orlando, Florida used a base sheet on the deck but not on the plywood wall and they burnt a $650,000.00 home to the ground, it was new construction, thus no one was living there yet and no one noticed the fire until early in the AM when they seen the fire ball.
I not only would not torch down with out a base sheet and proper flashing's like Ed said,
I also would not hire a roofer who suggest doing so.
God Fearing, Husband/Father, US American, Pool Shooting Roofer
Slyfox is offline   Reply With Quote
Old 06-11-2009, 07:15 PM   #8
Thanks for all of the informative replies, folks. Looks like I need to get more bids.
66merc
Old 06-11-2009, 07:54 PM   #9
Heh I said it first,Ed just gave a more detailed response,lol
Old 06-11-2009, 09:23 PM   #10
Residential Roofer
Slyfox's Avatar
lol, sorry my response should have read, Like johnK and ED said
Peace EH!.
Old 06-12-2009, 02:15 AM   #11
I'll forgive you,EH!Lol Take care
More On This Topic
Torch Vase Base
Torch Vase Base by Expert Village
So once you have the base of your vase about as thin and in the shape that you think you want it, go ahead and take your torch and get that going. Turn the wheel rather slowly, kind of, well, maybe a medium speed, and then hold the flame up to the pot... Read More »
A garden party or barbecue is not complete without tiki torches. These inexpensive bamboo stalks can be the quintessential decorative feature for your backyard. Before you twist them into the ground, consider these tiki tips for arranging a more... Read More »
Clay Pottery Torching Tips
Clay Pottery Torching Tips by Expert Village
Now in order to take this piece off the bat, you can let it dry for a little while before you cut it, or you can do like I do and torch it. That way you don't have a bunch bats sitting out in your studio. You just have the piece. Now the first thing you... Read More »
My name is Wayne Phelps. I am a professional magician and this is Expert Village.com. Check this out; this is a really cool trick. This is called the Hindu color change. It uses the Hindu shuffle. Take a blue deck and all you do is just shuffle the cards... Read More »
In northern climates where snow and ice are frequent visitors to our homes, one question that is asked frequently is, "How do you get rid of ice on a wood deck?" One of the big concerns is if it will harm the wood or deck itself. There are many methods... Read More »
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 09:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 06:08 PM
Torch Roof Replacement Question Chad262 Roofing 6 09-21-2005 09:29 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
