Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-23-2012, 01:20 PM   #1
torch down roof repair or replace?
I was asked to paint and restore a deck an as I got to its roof ran into a lot of flashing failure in inspection I found that previous owner had masked a serious overall flashing and drip edge failure. I can repair the sheeting tails and flashing properly just lost lost on the drip edge. The roof rolls up at all sides with downspouts at the corners. The drip edge is a capon top of that roll. How do I replace and seal that on top of the roofing material or is a system that will fail again? And what is the determining factor in deciding replace or recoat on torch down itself (whole roof)?
ohmiahgod81 is offline   Reply With Quote
Old 09-23-2012, 01:24 PM   #2
You post is some what confusing.
Can you post a picture to clear it up?
Old 09-23-2012, 02:25 PM   #3
Small roof leak - how to repair OhmZoned Roofing 10 11-22-2011 03:49 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing 10 04-13-2010 11:02 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing 4 02-18-2010 08:03 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
coating torch down roof Betsy G Roofing 4 10-14-2007 12:40 PM
