Torch Down Roof Problem - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-15-2007, 01:15 PM   #1
Torch down roof problem
Hello. In recent higher-than-usual winds, my torch down roof peeled back about six feet from the corner. Can I repair this by applying roofing cement or can someone recommend another material or method.
Thanks,
Dan
Danimal39 is offline   Reply With Quote
Old 04-15-2007, 01:44 PM   #2
I presume that the base sheet underlayment was also detached with the modified bitumen membrane as well.
Their is an asphaltic glue/adhesive that may work for this situation.
The better situation would be to cut off the detached area and re-apply new modified bitumen.
Take care of the reason that the edge detail allowed for the membrane to become detached in the first place.
I personally prefer to overhang all perimeter edges with about 4" of membrane, where the white salvage edge line is located and then use an extruded 1/8" thick aluminum termination bar secured with wood tek gasketed screws applied every 6" to 12" on center in the pre-puncheds out oval slot holes.
Ed
Ed the Roofer is offline   Reply With Quote
Old 04-15-2007, 08:26 PM   #3
Reply to Ed
Thanks so much for your assistance.
Dan
Old 04-17-2007, 05:50 AM   #4
Commercial Roofing
AaronB's Avatar
Ed, do you use term bar for over the roof edge?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-17-2007, 08:06 AM   #5
I wrap the 4" salvedge edge down onto the fascia board or behind the gutter. In the case of a gutter, I also strip in an addittional piece that goes into the gutter.
The overhanging membrane on the fascia board gets secured with the aluminum termination bar fastened with neoprene gasketed wood tek screws.
I have never seen an edge get blown off this way.
On certain architectural applications, I use a 2 piece sheet metal edge system with a built in cant and bring the membrane over the bottom nailer piece and then install the snap on decorative cover piece, such as Hickman Sheet Metal old detail which has been copied by most other sheet metal fabricators.
About half way between where you and I are located, Bremer Sheet Metal makes a good in-house system. I think that they are in Glendale Heights. It has been a while since I have used them though.
Ed
flat epdm roof problem larry42 Roofing/Siding 5 04-28-2007 10:03 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
replace tar & gravel roof with shingles & torch down rt1035 Roofing/Siding 4 12-17-2005 05:39 PM
garage roof problem ERIK2173 Roofing/Siding 3 11-03-2005 07:44 AM
Torch Roof Replacement Question Chad262 Roofing/Siding 6 09-21-2005 07:29 AM
