Torch Down Over Existing? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-25-2007, 12:49 PM   #1
Rewards Points: 24
Existing roof is Ruberoid Torch smooth installed about 15 years ago. Never was coated. Roof is in reasonably good shape for its age, which is surprising.
Any concerns with putting new torchdown over the existing roof?
lute is offline   Reply With Quote
Old 07-25-2007, 01:24 PM   #2
That is probably the best scenario to have. Be sure to be safer than usual, because the additional bitumen can heat up excessively upon reroofing it.
All flashing details remain just as critical as during the initial installation process.
Ed
P.S. Try to avoid running the seams exactly on top of the previous initial roofs seams. The humps will be more exaggerated and tend to slow down the water drainage.
Ed the Roofer is offline   Reply With Quote
Old 07-25-2007, 04:11 PM   #3
Rewards Points: 24
Thanks for the reply, Ed. That's the kind of info I was looking for.
[QUOTE=Ed the Roofer;54488]That is probably the best scenario to have. Be sure to be safer than usual, because the additional bitumen can heat up excessively upon reroofing it.
OK. Would you expand on this for me please?
Old 07-25-2007, 09:03 PM   #4
Rewards Points: 150
It can make a real good roof in this case.
RooferJim is offline   Reply With Quote
Old 08-01-2007, 11:45 PM   #5
the roofing god's Avatar
Send a message via MSN to the roofing god
it`ll work good,beware the flame,and keep an extinguisher handy if you`re not experienced(or even if you are)
the roofing god is offline   Reply With Quote
Old 08-04-2007, 11:51 AM   #6
Commercial Roofing
AaronB's Avatar
Is it wrinkled or buckling? Is it taking water? Are the flashings still secure? Is the substrate in a roofable condition? Are you going to use a base sheet? What method of attachment is to be used?
Can you post any pictures for us? We like pictures.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Torch Down Instructions Needed - DIY MikeinBurien Roofing/Siding 86 10-07-2012 12:21 PM
Remodeling upper...existing runs to the basement? wease Electrical 3 02-11-2007 11:49 AM
Torch Roof Replacement Question Chad262 Roofing/Siding 6 09-21-2005 08:29 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
