Torch Down - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-11-2010, 10:02 PM   #1
torch down
I put 3 tab shingle on low pitch roof and leak, is it ok to torch down over shingle, under the shingle is ice guard, or do I need to tear off shingle?
scll is offline   Reply With Quote
Old 12-11-2010, 11:11 PM   #2
If you don't know that I don't think you should be torching
johnk is offline   Reply With Quote
Old 12-12-2010, 08:22 AM   #3
Residential Roofer
Slyfox's Avatar
I concur.
You should not torch over shingles.
You should not torch directly over ice guard.
You should not use a field torch too torch near walls, rakes, eaves or any penetrations in the roof, use a detail torch for those area's.
You should have a fire extinguisher and fire retardant powders with in hands reach at all the times.
You should be aware of your surroundings at all times making sure there's no smoldering of insulation, underlayment materials or anything else during your work or after you have finished.
Best advice, find a safer route.
Hire a pro or use a different material such as a single ply system.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 12-12-2010, 11:17 AM   #4
Doing This Way Too Long
Rewards Points: 532
scll, if you happen to have read other topics here on torchdown, you will notice that none of us think it is a DIY system. I've been doing it for 20 years and still am paranoid and nervous when we start a job. There are numerous details and techniques involved to get it done properly and if you miss even one, you will have an improper installation. On top of that it only takes one wrong move to barbecue the patient.
In this situation we tend to encourage the DIY'ers to check into the self-adhering SBS systems. They are much more DIY friendly. Google Flintlastic SA or GAF Liberty SA.
Either way, yes you should start with bare, clean, dry wood substrate.
OldNBroken is offline   Reply With Quote
Old 12-14-2010, 02:15 PM   #5
I agree
I have seen many buildings burnt to the ground from inexperienced torching. Would not recommend it. I would recomend a peel & stick.
AltecRoofing is offline   Reply With Quote
Torch down info sjacobso Roofing/Siding 8 07-24-2012 03:54 PM
Torch on roof membrane on deck canada55 Roofing/Siding 36 03-03-2011 03:18 PM
Flat roof resurface--EPDM, Torch Down, Cold Applied bitumen mgfuns Off Topic 3 07-07-2010 01:10 PM
Coating over torch down before new decking bobhpete Roofing/Siding 2 05-17-2008 09:39 PM
Torch Roof Replacement Question Chad262 Roofing/Siding 6 09-21-2005 08:29 AM
