Too Much Under First Row Of Shingles? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-03-2013, 07:39 PM   #1
Rewards Points: 127
Too much under first row of shingles?
Hey so I've been deciding on what gutter guards to get and I'm going to go with a type that locks in the gutter and slides under the first row of shingles... I was also planning on putting gutter flashing on... Which you nail under the first row of shingles.. I am also moving a downspout to the other side of the house so I'm re pitching the gutters... Might use the hangers for that that you tack under the shingles... So my question, is the flashing and gutter guards and occasional hanger too much to put under that first row of shingles? They are all thin, but still seems like a lot
sh40674 is offline   Reply With Quote
Old 04-03-2013, 08:44 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 834
Not usually.
Drip edge and gutter protection systems are pretty standard.
Not sure what bracket you are considering but I would just use the ones that screw into the fascia board.
Old 04-03-2013, 08:48 PM   #3
Rewards Points: 127
I was gonna use the ones that screw in but I already have spikes in...so if I moved them up just a little chances are it would break through into the hole the spike was in... That or move it to the left or right some but then I have the old holes from the gutter spike showing
Old 04-03-2013, 10:34 PM   #4
Rewards Points: 12,794
Good luck trying to get those spikes out without damaging the gutters.
Old 04-04-2013, 03:05 AM   #5
Rewards Points: 127
Naw they are pretty loose... The spots I'm not using hangers I'm going to replace with screws
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 08:50 PM
transitioning between cedar shingles and asphalt shingles James77 Roofing/Siding 11 09-06-2012 04:30 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 07:29 PM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 04:42 PM
