-   -   Too much soffit venting? (http://www.diychatroom.com/f9/too-much-soffit-venting-165333/)
Hogan773 12-01-2012 11:22 PM
I am trying to minimize ice damming.
Just had pros come and air seal the attic floor, and they added 12 inches cellulose over existing fiber batts.
Now my attic gets "closer" to the outdoor temps than it did in the past, but still about 10-15 degrees higher.
I'm thinking of cutting in a few extra soffit vents because it is an easy job. I have a hip roof so have metal square roof vents, and a bunch of 16x4 soffit vents. Many were partially covered with dust so I scraped them off.
Thinking of adding in a few 16x8s to open up even more airflow.
My QUESTION is, they put in a bunch of DUROVENTS in the rafters when they did the air sealing. The Durovents have a net free air of 18 sq in or so. Does adding more soffit vents help or am I now dealing with the DUROVENTS as the constraint in my system? Also I am not an expert but are soffits generally open a bit....I mean between the rafters, or if you put a big vent in does it ONLY go up that channel? I can't really reach in there right now to see if the soffit rafter bays are open to each other.
I don't want to get up there with my jigsaw if it aint gonna help because only so much air can get through the Durovents.
Windows on Wash 12-03-2012 08:20 AM
Post up a picture and you will get more feedback.
Theoretically you can have too much soffit venting if the system is out of balance dramatically but most homes are out of balance in the wrong direction (i.e. too much exhaust and not enough intake).
Hogan773 12-03-2012 09:41 AM
I cut in one new 16x8 yesterday afternoon. Pretty easy job.....just did it reaching out the window rather than get up a ladder. I confirmed that my soffit is "open" between the rafters which means that there is a triangle-shaped area that is open across all the rafters near where the soffit joins the house. I wasn't sure before, and was thinking that if each rafter bay only flowed up into one Durovent then it wouldn't be useful to add a 16x8 (65 NFA) vent if the baffle only allowed 18 NFA to come through. Given that the whole soffit is "open" in a sense, then I decided to add the larger vent (vs a 16x4) because air should be available to find its way up all the different baffles.
I may add a couple more vents just to ensure that my intake is not the constraint. It's an easy DIY job, while adding more mushroom vents at the peak is not something I'm going to attempt myself for a variety of reasons.
Grumpy 12-03-2012 02:19 PM
10-15 degrees hotter than outside really isn't a problem if you ask me, in my unscientific opinion. Too much soffit venting is when the birds can get in. Until that point, I have never read any study suggesting that there can be too much properly installed intake. There shold be at least 3/4" preferrably 1.5" between the bottom of the sheathing and top of the insulation. Too bad they didn't install rafter baffles... Did they?
If you let me know the square footage, I would be happy to run a calculation and let you know approximately how many minimum vents would be recommended. However on a 1,000 sqft foot print you'd want about 18-23 (depending on slope) 4"x16" undereave/soffit vents.
I have no idea what a durovent is, nor if it will interrupt the intake of the soffit vents. Also I hope they didn't install so much insulation as to block the intake from the soffit vents. And how many is a bunch, when it comes to attic ventilation, we deal with specific formulas not just guess work ;) I couldn't find a mathematical translation for a "bunch".
Furthermore what kind of exhaust do you have? Is that the durovent? I'm too lazy to google it :)
http://reliableamerican.us/articles/...ice-daming.htm
Hogan773 12-03-2012 02:53 PM
Durovent ARE the baffles
I have a 40 40 house. Some of the attic is taken up by cathedral ceilings.
I calculated using the 1 to 300 rule. I am just on the edge with the current. 4*16 that are there.
Windows on Wash 12-03-2012 05:52 PM
1:300 is great but if the top side of the envelope is tight and insulated, you are usually pretty golden.
Gary in WA 12-04-2012 11:07 PM
Page 603-618, I wish it was all there, a good read: http://books.google.com/books?id=Z8a...0vents&f=false
Long as you are close to balanced or meet other guides, the 300 rule is fine, per code (minimum); http://publicecodes.cyberregs.com/ic...9_8_sec006.htm
Scientifically: http://www.greenbuildingadvisor.com/...-venting-roofs
Ice dam prevention, enough vents, (Grumpy will even like this one);http://www.brainerdhomeinspection.com/roofve~1.pdf
Gary
Hogan773 12-04-2012 11:18 PM
Great info Gary - thanks
I especially like the ice dam research and the "22 degrees" number....very helpful. I've always instinctively known that the ice dam problems occur most when it is very cold outside, not just 29 degrees. I'm hoping that with my new insulation sealing and more venting, I have a fighting shot at getting the attic close to freezing when it is 20 degrees outside. Might not get all the way but I figure if I'm a few degrees off it will be ok. Last winter before the air sealing my attic would never get below 41-42 degrees even when it was 15 outside. This year it got down to 35 last week when the temp was about 21. That was before I cut in my new 16x8 vent. Still planning on cutting in another few if the temps stay warm enough to work.
Hardway 12-05-2012 12:26 AM
I have 40' of Soffit and Ridge vent on both sides of the roof.. The attic temp is the same as it is out side. No ice dams.
Grumpy 12-05-2012 10:20 AM
Gary
Sooo many words! Just skimming my brain hurt LOL. I'll have to read it later when my brain is not in hyper-drive.
jagans 12-06-2012 02:57 PM
I really dont think that you can have too much ventilation through your soffits, because you can only get what you can get based on net area intake. Whatever you do dont use typical bug screen for soffits, it will become blocked with atmospheric dirt in about 4 months. If you are really having trouble with ice damming, consider using a rigid insulation with a high resistance value like Polyisocyanurate at the pinch condition near the eaves. It has a rated value of around 6.5 per inch of thickness. Styrofoam EXPS is good too at 5 per inch and it does not absorb moisture. You could cut in 3 inch iso, then foam the edges tight. continue back 4 feet from the eaves, then go from there with blown in whatever. Fiberglass, Cellulose, or whatever.
I already explained ice damming in another post, not sure if it was here or not. Read it if you can.
Hogan773 12-06-2012 04:00 PM
Will search for your post.
I sort of agree re soffit....I figure I should open up the soffits enough that whatever air is rising out from the mushroom vents on the roof has NO PROBLEM with getting replaced somewhere in the soffit intake system.....and more would allow easier intake and also give a fudge factor should some of the vents become partially blocked over time, etc. At this point I'm going to add another 3 16x8s outside of windows where I can easily access without getting way up on a ladder and killing myself. 4 total 16x8s is an added 240 NFA which when added to the existings should be plenty. I have a complicated hip roof with 4 mushrooms way up top (240 NFA), 3 more in slightly lower peaks, plus 8 feet of ridge vent in an area of the roof that is above a cathedral room and somewhat isolated away from the rest of the open attic. Hopefully the 3 mid-level mushrooms are acting to exhaust warm air and not becoming intakes for the top 4 mushrooms, although I know that is a possibility. I do see air moving up from the soffits through the baffles as I can see spider webs swaying in the air so I know some air is coming in from the bottom.
Re: foam board insulation are you saying I should use that at the very edges along the attic floor? I think its probably too late now. The guys put in the baffles then stuffed in fiberglass batts at the edges which help to hold in the blown cellulose.
Here is a question......is there any benefit to somehow tacking up polyiso foam boards DIRECTLY TO THE ROOF DECK UNDERSIDE in specific areas where I'm trying to prevent melting, ie on the front area where I've had problems? Basically would adding a foam board to the plywood deck help to keep that decking more like the temp of the outside? Or would it just help insulate the deck from the bottom while the snowpack is insulating it like a blanket from above? Also not sure how I could get the foam board on in an airtight seal ....if you didn't then any attic air would just work up into the gap and it wouldn't do anything.
Windows on Wash 12-06-2012 04:10 PM
If you can't get it sealed up, it may serve no purpose. If the outside top plate is seal up tight and you have good R-value at the narrowest point in the roof, you should be fine.
Hogan773 12-06-2012 04:49 PM
I guess I could spray a little layer of foam on the underside of the sheathing in select areas....but still trying to figure out if that is a good or bad thing. Let's say the attic temp is 35 when the outdoor air is 22. Will a layer of foam keep the roof COLDER because that 35 degree attic air can't "touch" the plywood sheathing.....or will it actually mean that the roof is "blanketed" on the top from snow (with good R value) and the bottom from foam insulation, meaning the actual roof will not stay cool.
BTW I like the idea from another thread about trying to use a metal flashing to prevent gutter ice from working back under the drip edge. I believe that is my problem.....a valley and gutter fills with ice and there is water in the soffit that then works its way down the outside brick veneer.
jagans 12-06-2012 05:13 PM
To Hogan
No, the whole idea is to keep the underside of the roof deck (Including the roof deck at the eaves) close to the outdoor temperature. did you read my post on ice damming? Most of the guys posting on here don't seem to understand what is going on, so it is easy to be misled.
