Too cold to shingle
I have installed roofs when it was 8*.,it is not fun but it was a success.Most problems with roof installations in the brutal cold is due to the installer and not necessarily that of the material.
Slamming bundles down causes them to crack and break.Throwing single shingles also cause damage to corners and other parts of the shingles.Improper air pressure regulation causes blow through.
The shingles are not the only component that requires special handling in cold temperatures,vents,pipe flashing,RidgeVents,vinyl soffit,siding/J channels require special care too.
As always it is up to the installer to know how to install roof systems depending on season.
