tips for installing Provent insulation baffles?
I found this thread interesting because I need to do the same thing on my home in Florida.
That home only has 6" of fiberglas, and it looks like the batts are in some places a bit too tight to allow the soffit vents to work properly.
Before I add additional insulation, I'll need to install these baffles. I've been wondering how best to do this.......either crawl up into the attic and using a small rake or hoe, pull the batts back enough to shimmy and shove the baffles down,,,,,,,,,,OR.......
Perhaps I can remove the soffit from the outside, and push the baffles up tight against the bottom of the roof sheathing. I'm not sure.
I have a roofing company doing a complete tearoff in October, when I will be back down there. They are tearing off the existing roof, installing new ridge vents and additional 4' low profile vents up by the ridge vents, putting peel and stick on everything, then new high wind rated 30 year shingles.
The insulation project is a separate project, but both may be done in October.
Frank D.
