Tips For A 2 In 12 Pitch Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-29-2011, 02:52 PM   #16
Would the GAF stormguard be comparable to the ice and water shield? It never snow here and the weather in mild
Dave
Dave K is offline   Reply With Quote
Old 04-29-2011, 05:50 PM   #17
Residential Roofer
Slyfox's Avatar
Dave
With out the threat of ice forming and backing up under the shingles the biggest problem would be wind driven rains, in that case the two ply felt may very well be enough.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 04-29-2011, 06:44 PM   #18
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Dave
Here you go - from the manufacturer:
http://www.gaf.com/Documents/Shingle...-43-817-v1.pdf
seeyou is offline   Reply With Quote
Old 05-07-2011, 12:02 AM   #19
I would like to spend the extra money to put down GAF stormguard in the low slope part of the roof. I took a look at the box that the stormguard is packed in and it does not say anything about low slope roofs and it says that it should only be applied full coverage under metal roofs.
Does anyone have first hand experience using stormguard in large areas for low slope roofs?
Thanks for all the help
Dave
12/12 Roof Pitch - cutting rafters JustAHack Building & Construction 11 10-06-2010 08:43 AM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-20-2010 11:50 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
10/12 Roof Pitch jonathan03 Roofing/Siding 5 04-03-2010 09:24 AM
Changing a roof pitch dcsobob Building & Construction 0 12-29-2009 10:28 AM
