Tips For A 2 In 12 Pitch Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-28-2011, 02:19 AM   #1
Tips for a 2 in 12 pitch roof
I am going to be roofing a building that has some areas that are 2 in 12 pitch. I am going to be using comp shingles and double felt. Please share any tricks or tips for making this roof water tight.
Dave
Dave K is offline   Reply With Quote
Old 04-28-2011, 06:09 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
2/12 is very low for composite shingles.
Ice and Water shield as an underlayment.
tcleve4911 is offline   Reply With Quote
Old 04-28-2011, 07:55 AM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
To be honest, the shingles and double felt will work about as well as leaving just the plywood to fight the elements. About 6 months later, some of the plywood will be saturated. Within a year, the leaks will show inside and the plywood will be falling apart. Plan on redecking it then.
Or, you could look into SBS low slope. Match the roof color. Put down the nailable base sheet. Add one, or two inter-plies, then, the matching color granulated cap sheet.
Here's the tech stuff http://technicaldatabase.fsbp.com/do...2%7Cpid=808%5D
More http://www.mbtechnology.com/roofing-...lection-guide/
More http://www.firestonebpco.com/roofing/asphalt/sbs/
The detail work is about as complicated, or not, as shingle work.
tinner666 is offline   Reply With Quote
Old 04-28-2011, 10:18 AM   #4
You guys are bumming me out :-(
I am surprised that it is not do-a-ble. A very reputable pro roofer said he could do it with shingles. I guess it could be a little steeper than 2/12 I will have to take a better measure on it today.
Dave
Old 04-28-2011, 02:18 PM   #5
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Dave
Most dimensional/architectural shingles are spec'd down to a 2/12 with special underlayment considerations. I know some of them have abandoned the double felt spec in favor of I&WS.
I've have done this installation several times over the last 20 years and have had no problems. Is it the best solution? Probably not, but it can be done.
seeyou is offline   Reply With Quote
Old 04-28-2011, 04:36 PM   #6
In a little over my head
Rewards Points: 706
I am not a roofer or play one on TV or the internet. But I've lived in a house with a 2.5 in 12 pitch for 20 years. Shingle roof. Standard felt. No leaks or problems. I'm also getting a new roof this week. (That's why I'm checking this forum) Keeping my fingers crossed.
ratherbefishing is offline   Reply With Quote
Old 04-28-2011, 08:04 PM   #7
The roof is 2.4/12 does that help? I am torn as to what I should do. Many roofers tell me that double felt ($60.00) is all I need or I can do a ice/water layer ($300)
Old 04-28-2011, 08:05 PM   #8
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Google the brand/model of shingle you are planning on installing and read the installation instructions.
Edit: And it's half lapped felt, not double felt. They're two different things.
Old 04-28-2011, 08:33 PM   #9
I was planning on GAF timberline. Are some shingles better than others for low pitch roofs?
Old 04-28-2011, 08:48 PM   #10
Pro Slate Roofer
tinner666's Avatar
If you're bound and determined, use roofing nails. HDD, not those EG felt nails. They'll be brown dust in no time.
I did it once about 11 years ago. http://rcs.si-sv2628.com/show_album_...&file=1976&s=0
I&W shield. Elks, at a 4" exposure, HDD nails. I dutch-lapped the shingles about 6" to 10", random lap widths, so there are NO joints. It's still going strong.
Old School, but the method does work.
You should also note that shingles today are NOT waterproof. Just water resistant. I've seen them leak in the center of a roof on 12/12 pitch. No holes tears, or other damage either. They just absorb water.
The ones in the pictures are undamaged in any way. 8 years old. The amount of water coming through was ruining the house. The pix were taken after a drizzly night.
Tips for a 2 in 12 pitch roof-water-soaked-shingles-8-.jpg   Tips for a 2 in 12 pitch roof-water-soaked-shingles-3-.jpg
Old 04-28-2011, 09:05 PM   #11
Pro Slate Roofer
tinner666's Avatar
The link didn't work. Let's try again.
If this one is bad too, go to this one, and select 'Low Pitch Shingles
http://www.rooferscoffeeshop.com/pho..._list.asp?u=30
Steve is still getting kinks out of his site where I store albums.
Old 04-29-2011, 05:36 AM   #12
kimboy is offline   Reply With Quote
Old 04-29-2011, 06:29 AM   #13
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Canadian Asphalt Shingle Manufacturers' Association has a nice brief on the concerns of low slope shingle applications.
http://www.iko.com/advantage/CasmaPd...lopedRoofs.PDF
You are right to be concerned about this application.
Just pay very close attention to details and don't skimp on materials.
I think I already heard you balk at $600 for Ice & Water Shield.
That's nothing when you can be confident that your roof doesn't leak.
Old 04-29-2011, 07:41 AM   #14
Residential Roofer
Slyfox's Avatar
I believe the wetness your referring to is a combination of condensation and side lap moisture, just guessing tho seeing as how I didn't see it in person.
I did do an experiment with GAF timberline, Tamko heritage and Certainteed landmark (controlled) and neither of the shingles allowed water to pass through.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 04-29-2011, 07:48 AM   #15
Residential Roofer
Slyfox's Avatar
Dave
The problem with low slope shingle roofs is every and any mistake during installation will result in 100's of dollars in damages later, and the later is normally just a few years or sooner.
The main thing is to find an installer (roofer) who you trust, has a proven reputation and most importantly knows your regional weather.
If it were me I would not install the shingles on any thing below a tru 3/12 with out full ice & water shield covering the entire deck (sheathing).
Facebook <> Twitter
12/12 Roof Pitch - cutting rafters JustAHack Building & Construction 11 10-06-2010 09:43 AM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 11:02 PM
10/12 Roof Pitch jonathan03 Roofing/Siding 5 04-03-2010 10:24 AM
Changing a roof pitch dcsobob Building & Construction 0 12-29-2009 11:28 AM
