A Tiny Sag Noticed On Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-24-2013, 12:34 PM   #1
Rewards Points: 37
A tiny sag noticed on roof
Bought a house a few months ago. When I was on roof this week for gutters, noticed a 2 small depressions on roof surface. When I went in attic to investigate, I saw this:
What am I looking at here? Is this something to be dealt with immediately, or can it wait until spring (if attention is needed, of course)? Is this something I can repair on the inside by adding some piece of wood to brace?
If this can be done by a diy-er, and needs to be done now, can you please explain in a little detail to someone who can figure out, but needs a clear picture?
I have been leaning on you guys for a lot of knowledge since buying this house. I really appreciate all you do!
kah5683 is offline   Reply With Quote
Old 11-24-2013, 12:43 PM   #2
Rewards Points: 13,468
Someone that installed that roof was sleeping or missed class the day they talked about installing H clips between the trusses or rafters.
http://tecotested.com/techtips/tt_edgeclips
To late now, now your going to have to add blocking from below to support it.
Just measure the distance between the rafters and cut a 2 X 4 that length. Tap it in place and toe nail it to the rafter.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
kah5683 (11-24-2013), roofermann (11-24-2013)
Old 11-24-2013, 04:29 PM   #3
roofermann's Avatar
Rewards Points: 401
Joe's got it, wait till it warms up to reduce the chance of cracking the shingles.
roofermann is offline   Reply With Quote
Old 11-24-2013, 05:14 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,500
2x4 rafters 24" OC? Really?
Hard to tell from the pics....but that almost looks like 3/8" plywood
Old 11-24-2013, 05:21 PM   #5
Hardly think lifting the shingles a 1/2" is going to do any harm.
Old 11-24-2013, 05:35 PM   #6
Rewards Points: 37
House is 40 years old. Here is another pic of the attic:
Old 11-24-2013, 05:43 PM   #7
JOATMON
ddawg16's Avatar
Are those plumbing vents sticking up?
Old 11-24-2013, 05:58 PM   #8
looks more like the vent pipe from the bathroom fans.
Old 11-25-2013, 02:30 AM   #9
roofermann's Avatar
Rewards Points: 401
No idea where the guy is, could be stupid cold. No harm in leaving it til spring. Those possible bath and kitchen vents dumping in the attic are a bigger issue.
Old 11-25-2013, 03:46 AM   #10
747
registered
747's Avatar
Rewards Points: 534
When its time for a new roof. The whole roof is probably going to need new sheathing. Seeing how its 24 oc it has to be thick which isn't cheap. Stay off the roof. Do like joe said. Finally if those are exhaust vents from bathroom. Sure hope your not in a cold weather climate. The moisture from those vents could freeze on the sheathing.
747 is offline   Reply With Quote
Old 11-29-2013, 12:23 PM   #11
Rewards Points: 37
Yeah, those are fan vents from bathroom. Talked about it in another post. Was going to run a flexible duct to current vent in roof, but was suggested I put new hole in roof over both fans with a new vent to outside. Waiting until spring.
Unfortunately, I am in cold area - suburbs of Chicago.
Old 11-29-2013, 02:31 PM   #12
24" on center is common, but there should have been thicker sheathing and H clips in a snow area.
Old 11-30-2013, 02:00 PM   #13
Registered User
Rewards Points: 5,498
Take another picture of an ink stamp on one sheet for us, please. The plywood used may be code-approved for the application. H-clips may/not be required, depends on the rating given on the stamp; http://www.strongtie.com/products/co...pscl-psca.asp#
Code is similar; http://publicecodes.cyberregs.com/ic...?bu2=undefined
Center support on 24" is always good even on rated for the span applications. IMO, the one edge went opposite the other due to expansion from humidity and was not gaped 1/8" at edges at application. The fasteners hold the sheet stationary, the edges can't move toward each other so they move in elevation. If the sheathing is tight- no gaps- during the summer, the blocking may only even the two edges temporarily until humidity (seasons) changes again. Solution is to remove material from one sheet for a proper/required gap. (OR) The extra moisture from the fans is causing the buckling, fix that ASAP and the sheathing may shrink down flush alone (don't add a block until ply is dry). Next comes mildew (mold) after the ventilation can't keep up with moisture you are forcing against the wood sheathing. The 1/2" three-ply plywood looks similar to yours, though we can sit here and guess all day....... need a pic.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Windows on Wash (12-09-2013)
Flat roof repair/replacement questions zmt Roofing/Siding 4 02-23-2010 11:24 AM
Blown Insulation - Flat roof AndrewF Roofing/Siding 1 12-31-2009 06:41 PM
Laying new roof after removal of old roof rupal Roofing/Siding 9 11-30-2009 04:00 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 09:07 AM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 05:37 PM
