Tin Roof Help - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-25-2009, 10:12 AM   #1
tin roof help
I'm going to put on a new tin roof over the old shingles , the roof is 15'x40
the sheets i can get are 8' and 12' but i need to go 15' so i plan to put a 12'and 4'this will let it the 4'lap the 12' one foot , do i want to keep this seam
the same across the roof or stager the seam by putting the 4' on top then on the next row put the 4' on bottom then back on top for the next . what do you think?
dleighty is offline   Reply With Quote
Old 03-25-2009, 12:04 PM   #2
the Musigician
DangerMouse's Avatar
i'd do it in 4x8s myself.... that evens out the weight and makes one solid lap.
then when the cat runs across it on a hot day, ....oh never mind...
DM
Old 03-25-2009, 03:38 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
You need to stagger the seams. Put your sleepers down with that in mind.
tinner666 is offline   Reply With Quote
Old 03-25-2009, 03:40 PM   #4
thank you, thats what i was looking for,
Old 03-26-2009, 10:15 PM   #5
You do not have to stager the seams. 1' is a minimal overlap, I always go at least 2'. But I wouldn't put it over asphalt shingles or shakes. The metal gets very hot and you could set the roof on fire.
hayewe farm is offline   Reply With Quote
Old 03-30-2009, 06:02 AM   #6
thank you for the good info . it will help .
Old 04-09-2009, 09:15 PM   #7
In N.Z we use metal roofing a lot We also have extremely hot summers, up to 40deg celsius. As an underlay to the roofing we use a tar based paper. As a volunteer fireman I have not seen a fire started by this manner.
lemuzz is offline   Reply With Quote
Old 04-13-2009, 06:16 AM   #8
good info to know thanks
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
