Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-14-2012, 02:43 PM   #1
Tile roof
Does Behr have a paint for concrete tile roofs? If so, does the paint come with some kind of sealer? What does one use to apply the paint? Will a spray gun work? Please advise.
Adriene is offline   Reply With Quote
Old 11-14-2012, 10:41 PM   #2
Metal Roofing
Tile roof
They may have one, but if thats the route your going i would find something better.
The only one we have used is http://www.nutechpaints.com/ Time will tell, but it appeared to be a very highquality product. Again, we used them once but would not hesitate to use them again.
I am sure there are 20 others also, it just doesnt come up that often for us.
AndyWRS is offline   Reply With Quote
Old 11-14-2012, 10:47 PM   #3
Tile roof
Painting a tile roof
What do you do when it starts peeling?
Old 11-14-2012, 10:55 PM   #4
Metal Roofing
Tile roof
It is done a lot in So Cal, they do appear to stick very well. If they prep it right it should not peel. We used it for a standing seam job where the customer wanted to change the color instead of buying a new SS roof. We used those folks because they provided a 10 yr warranty on the paint. But respraying concrete roofs here is common.
If it peels in 10 yrs i guess they will need to do it again but it was a fraction the cost of a new SS.
Old 11-15-2012, 12:54 AM   #5
Tile roof
Respraying them is common here, too. Preparation and the correct primer/sealers is critical to success. I've seen coatings that have lasted 15-20yrs before needing to be redone, and plenty that failed after 4-5 years because the owner took the cheapest price & the contractor skimped on the prep.
mgp roofing is offline   Reply With Quote
Fix or Replace Roof Tile? greentrees Roofing 16 04-30-2012 06:50 PM
roof tile cleaning and preserving divinia General Discussion 2 04-11-2012 07:44 AM
Florida Roof Leak - Barrel Tile pm1035 Roofing 18 09-25-2011 08:21 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing 10 04-13-2010 11:02 PM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing 5 01-06-2009 07:51 AM
