Which Thickness Plywood For Small Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-27-2007, 10:00 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
Which thickness plywood for small roof?
What thickness plywood would you use for a small roof. It's for my portico entry rebuild and the dimensions of the sheathing are 4'x6' on each side including a 12" overhang on the eves and gable end.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-28-2007, 07:46 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
1/2" CDX....NOT OSB
- Build Well -
Old 07-28-2007, 11:40 AM   #3
Additionally, depending on the rafter spacing, either 12", 16", or 24", the panel thickness may be determined by your local code department depending on how much live load and dead load performance criteria you must be capable of meeting in your area.
A good site for thatinformation is the, Engineered Wood Products Association, also know as the APA, American Plywood Association, which now-a-days encompasses much more than just plywood.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-28-2007, 12:58 PM   #4
I have gas!
Thanks Atlantic and Ed,
Fortuneatly Atlantic is in my area so I can count on him to site codes for Massachusetts.
Old 07-28-2007, 01:39 PM   #5
Rewards Points: 768
Just a reminder to install the rough side UP on the CDX. It gets pretty slippery otherwise.
cibula11 is offline   Reply With Quote
Old 07-28-2007, 02:11 PM   #6
I have gas!
Taking time off while waiting out a passing shower. I didn't know there was a rough and smooth side. Thanks for the heads up.
Old 07-28-2007, 02:39 PM   #7
Here is the main link for the APA. It has some very useful publications, which require a free registration to be able to download the PDF files.
http://www.apawood.org/
Ed
Old 08-01-2007, 10:04 PM   #8
the roofing god's Avatar
Send a message via MSN to the roofing god
1/2" cdx for 16"on center rafter spacing,3/4" cdx for 24"on center rafter spacing
the roofing god is offline   Reply With Quote
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 11:12 PM
Flat Roof Suggestion gladiator Roofing/Siding 3 09-14-2005 04:31 PM
