Are These Vents Installed Correctly? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-30-2012, 04:11 PM   #1
Hello,
My son has a new house and I don't know if these two side by side vents are installed correctly. See attached photo. The house is in Oklahoma.
Best I can tell they seem to be this item
http://www.homedepot.com/webapp/wcs/...09&R=100344509
I am sorry for the quality of the picture.
Thanks,
Randal
sharingsunshine is offline   Reply With Quote
Old 06-30-2012, 04:25 PM   #2
Rewards Points: 12,856
Hard to say from that picture, it's to dark and to far away.
Is the hole for the air to get out on the lower side of the roof, or the high side?
Should be on the lower side if there scoop vents.
Old 06-30-2012, 04:35 PM   #3
the Musigician
DangerMouse's Avatar
If the scoops are on the high side, it means it's a "water cooled" attic.
....but only when it rains.
Or they are installed incorrectly.
DM
Old 06-30-2012, 06:14 PM   #4
Doing This Way Too Long
Rewards Points: 532
DM
OldNBroken is offline   Reply With Quote
Old 06-30-2012, 11:54 PM   #5
ParagonEx's Avatar
Rewards Points: 150
They look like slant back box vents and not bathroom vents. Would be odd to have two bathroom vents next to each other near the peak of the roof like that.
ParagonEx is offline   Reply With Quote
Old 07-01-2012, 12:26 AM   #6
Do there look like one of these?
http://images.search.yahoo.com/image...mb=Xwi4JCiNfjZ
Old 07-01-2012, 12:41 AM   #7
RFN-4A-LVN
Roofmaster417's Avatar
Other than not being symmetrical,,if they are not leaking then its a good indication that they might be installed correctly,,,or good enough to keep the water out of the attic.
Roofmaster417 is offline   Reply With Quote
Old 07-03-2012, 07:07 PM   #8
Hi Everyone,
Sure has been great all the help you have given me. I am trying to get another picture to further clarify which product is installed.
Unfortunately, I am separated from my son by 5 states so I will need to work around his schedule to get the new picture.
I will update soon as I get it.
Thanks,
Old 07-03-2012, 09:18 PM   #9
Roofing Contractor
May want to put some nails on the bottom of the vent pipe jack. Wind driven rain could creep in under and get into your attic.
Yes,
Unless the angle of the camera shot is not dead center up the slope looks like the vents got installed a little off center. If a tear off it could have been this way before the new roof went on???
dougger222 is offline   Reply With Quote
Old 07-14-2012, 10:47 PM   #10
Originally Posted by joecaption View Post
Yes, they are like the first one. I have attached a better photo. So what are they?
Old 07-14-2012, 10:50 PM   #11
Only way to tell is just go in the attic, if nothings attached to them then there just roof vents to allow hot air out.
Old 07-14-2012, 10:56 PM   #12
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 884
Most likely roof vents but a quick access into the attic and a flashlight will tell you for sure.
Old 07-16-2012, 11:27 AM   #13
thanks, I will have to check it out next time I am out there.
Ridge Vent with roof vents and Soffit vents apquery Roofing/Siding 10 08-08-2016 10:28 AM
5 year old home - builder never installed attic vents DIYguy2000 Building & Construction 20 09-16-2011 10:04 AM
Multi rib metal roof on double wide...static vents wpilotm Roofing/Siding 0 09-10-2011 04:51 PM
Ridge vents and roof vents jerry1967 Roofing/Siding 4 06-07-2010 06:40 PM
Hip Vents for 12/12 pitch roof - any suggestions woodworker2000 Roofing/Siding 5 10-26-2006 11:31 AM
