Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-25-2008, 12:30 AM   #1
thermostat and humidity controls for electric attic fans
I am completing a 3300 square foot shop and am using two electric gable end fans. The shop is split into two sections and one fan will be in each section. ( wasnt my choice but I am stuck with it)
My problem is this I have two heavy duty 220 volt gable fans that i got for very cheap that are new, quite,efficient and move enough air to solve all the venting needs I should encounter but I am not finding thermostat or humidity sensors capable of handling their electrical load.
The fan motors are 1/3 hp, start up amperage could hit 8 amps and probably stabilize at about 3 to 4 amps per motor. I want to vent this via temp and humidity and would be happy if I could find something to do either side and just wire it up via both switches but I would really like to find one combo unit.
One other option is to just run the fans on a timer and guess a little about how long and what times during the seasons to run the fan but I would really like to find a solution. I could install a temp gauge and humidity sensor and probably figure this out a little more accurate than just turning them on and off but I have to think with all the large buildings out there theres got to be 220 volt switches available for my needs. The shop i have now suffers from improper ventilation and its exceeds draft style venting codes and they are free and clear. And I am going to do what ever i can to cure this in my new shop.
Any one have any thoughts
Andy
lowlysubaruguy is offline   Reply With Quote
Old 09-25-2008, 12:50 AM   #2
Check at a hydroponic shop,they carry stuff like that.Mmmm...I think
johnk is offline   Reply With Quote
Old 09-25-2008, 08:32 AM   #3
Super Moderator
Have you stopped at an electrical supply house for contractors to ask them?
Ask for a referral from the supply house too.
Ed
Ed the Roofer is offline   Reply With Quote
More On This Topic
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip I will be talking about electrical safety. This particular sanding machine is 220 volts meaning it requires a lot more voltage than your typical outlet that you would have in your house... Read More »
One of the biggest challenges in maintaining a greenhouse is humidity control. Most plants enjoy a humidity of 50 to 60 percent, and this is a challenge to manage at times. The main goal is to avoid condensation on plants, which promotes mold and fungus... Read More »
Hi I'm Mark Sullivan for Expert Village. Today we are going to learn how to install a ceiling fan in your home. This is our electric meter that would measure voltage and oms and dc voltage. What we want to do now is this is a digital volt meter and we... Read More »
Hi! This is Jon on behalf of expertvillage.com. In this video clip I’ll be talking about electrical safety. You’ll notice that on our planer the plug does have three prongs. This third prong is essential in properly grounding your planer. If... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
