Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-02-2012, 12:18 PM   #1
Is there a way to prevent moss on shingles?
I live in Portland, Oregon where moss is the name of our game. I have used zinc strips, but they don't work when we have misty rain, fog or some condition where the water doesn't run down the roof. Is there something I can treat the shingles with to prevent the moss? ... or some other route?
Thanks in advance
Clarele2 is offline   Reply With Quote
Old 06-02-2012, 01:02 PM   #2
Exterior Construction
Windows on Wash's Avatar
Cut back trees if you have shading.
Other than that, you are stuck cleaning them.
Make sure all you venting is right as well.
Old 06-02-2012, 04:19 PM   #3
Remodeling Contractor
attach zinc strips to the top of the ridge. Rain will allow the zinc to leach off and coat the roof preventing moss or mildew growth.
Old 06-02-2012, 05:54 PM   #4
RFN-4A-LVN
Roofmaster417's Avatar
I had a house that had major moss.I am not sure about the specs for installation anymore since I have not used them in years but,,I installed them on the ridge and they worked only so far down the roof plane then moss was in force.
It was about a 30' rake line so I installed them on the ridge and in the middle about 15' off the ridge.That cleared it up.Also cutting your limbs back as Windows said helps alot.
Roofmaster417 is offline   Reply With Quote
Old 06-02-2012, 06:25 PM   #5
Doing This Way Too Long
How to prevent moss in Portland?
MOVE
Zinc strips are only effective down a certain distance. Can't remember what it is. 10 feet or 15 or something.
You have to install them in the field also in a place like Portland.
Or you can go buy a keg of 8d hot-dipped and just throw them up all over your roof.
OldNBroken is online now   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
Clarele2 (06-02-2012)
Old 06-02-2012, 06:28 PM   #6
http://blog.wetandforget.com/mossfreeroof/
Old 06-02-2012, 06:55 PM   #7
RFN-4A-LVN
MOVE
Old 06-02-2012, 09:17 PM   #8
He already said that he has used zinc previously. Wet and Forget is temporary and must be re treated.
Please keep in mind that zinc is a heavy metal and does accumulate and create environmental issues.
Tags
moss, roofing
GAF Roof... the best EdPDX Roofing 73 09-12-2011 06:53 AM
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing 9 09-04-2011 10:29 AM
moss on roof shingles mac109 Roofing 0 11-23-2010 02:32 AM
Help! -- what is causing these shingles to fail? imaginator Roofing 1 09-18-2010 07:29 PM
IKO Shingles - beware mtugrad1985 Roofing 7 02-10-2009 04:42 PM
