Is there a way to prevent moss on shingles?
I live in Portland, Oregon where moss is the name of our game. I have used zinc strips, but they don't work when we have misty rain, fog or some condition where the water doesn't run down the roof. Is there something I can treat the shingles with to prevent the moss? ... or some other route?
Thanks in advance |
Cut back trees if you have shading.
Other than that, you are stuck cleaning them. Make sure all you venting is right as well. |
attach zinc strips to the top of the ridge. Rain will allow the zinc to leach off and coat the roof preventing moss or mildew growth.
I had a house that had major moss.I am not sure about the specs for installation anymore since I have not used them in years but,,I installed them on the ridge and they worked only so far down the roof plane then moss was in force.
It was about a 30' rake line so I installed them on the ridge and in the middle about 15' off the ridge.That cleared it up.Also cutting your limbs back as Windows said helps alot.:thumbsup: |
How to prevent moss in Portland?
MOVE :laughing: :laughing: :laughing: :whistling2: :whistling2: Zinc strips are only effective down a certain distance. Can't remember what it is. 10 feet or 15 or something. You have to install them in the field also in a place like Portland. Or you can go buy a keg of 8d hot-dipped and just throw them up all over your roof. :thumbup: :thumbup: |
He already said that he has used zinc previously. Wet and Forget is temporary and must be re treated.
Please keep in mind that zinc is a heavy metal and does accumulate and create environmental issues. |
| All times are GMT -4. The time now is 11:05 AM. |
