Is There Any Danger If The Hot Water Heater Pipe Leading Out Of The Roof Has Become Disconnected? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-15-2011, 10:45 PM   #1
is there any danger if the hot water heater pipe leading out of the roof has become disconnected?
the pipe from the hot water heater that travels through the room is diconnected. is this a problem?
bridgett1459 is offline   Reply With Quote
Old 03-15-2011, 11:57 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what pipe? From the description of something going through the roof, I would have to guess you mean the flue pipe.
If that is the case, then yes, it is very serious, like in DEADLY, if it has come disjointed. You need to have that repaired, immediately or turn off all gas to the water heater. You don't want the heater running at all, including the pilot light if there is one.
The Following User Says Thank You to nap For This Useful Post:
mem (03-16-2011)
Old 03-22-2011, 12:47 PM   #3
Dangerous gases are circulating inside instead of being vented outdoors. A local plumbing company should be able to help if you are not able to reconnect yourself.
Avalanche Roofing & Restoration
www.springtxroofingcontractors.com
springtxroofing is offline   Reply With Quote
Old 03-22-2011, 03:48 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
Uh oh, no response for a while, I hope nothing bad happened to Bridgett.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
oh'mike (03-22-2011)
Old 03-22-2011, 03:56 PM   #5
nap
You talking to me?
nap's Avatar
Andy.
I was wondering the same thing when it popped up from this last guys post. I was hoping I would have gotten a response that first night. When you read things like this, it really does cause concern. I had a family down the road that nearly died from a very similar situation. Luckily they were found before anybody died.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Configuring pipe for range and water heater gas supply WillK Plumbing 11 05-16-2011 12:10 AM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 08:26 PM
