#1 |
Terra Cotta Roof
I am looking at installing a Terra Cotta Roof on a home we are looking to build and I will be using plywood, however, for the tiles do I need a special sheeting or something else to install this way there are no leaks. Thanks
#2 |
Commercial Roofing
Terra Cotta Roof
You need a beefy structure. The house has to be built to handle the weight of terra cotta.
Then you should consult the tile mfg for installation guidance.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Free inspection within 12 miles Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN! |
#3 |
Super Moderator
Terra Cotta Roof
That question can more precisely be answered by your architect for structural load bearing capabilities. The product weight can be supplied from the manufacturer though.
Ed |
| Display Modes | |
| Please help with the design of this roof | jaymay75 | Building & Construction | 1 | 05-06-2008 10:44 AM |
| Painting a terra cotta clay tile roof? | xoroniox | Painting | 2 | 12-13-2006 01:30 PM |
| Flat roof - Rolled? - leaks Advice? | JJ2001 | Roofing/Siding | 4 | 11-19-2006 07:17 AM |
| Venting a shed roof with 2/12 slope | atulc | Roofing/Siding | 5 | 08-25-2006 08:28 AM |
| Flat Roof Replacement Quote Questions | rocketmahn | Roofing/Siding | 1 | 01-02-2006 07:01 PM |
