Temperature - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-05-2010, 06:16 PM   #1
Temperature
Heard that you're not supposed to lay shingles when it's 40 or below outside. how does that work in winter with the builders up north. Is it a different grade of shingle or what.
Toolmaster is offline   Reply With Quote
Old 02-06-2010, 08:05 AM   #2
Residential Roofer
Slyfox's Avatar
All manufacturers have a low temp suggested, but only a few have a low temp demanded.
Meaning the majority of shingles can be installed in temps lower than freezing, there are additional steps/procedures for low temp installation and it will decrease daily production but it can be done and still meet manufacturer spec's.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 02-06-2010, 08:53 AM   #3
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Builders care more about budget and schedule than they do about quality. Furthermore many roofing companies in my area care more about keeping busy than quality because chances are if you are doing new construction you are not charging enough $$$ and have no savings so you MUST work or starve. These same roofing companies would rather "risk" making a mistake and fix it if it laks at a later time, meaning a leak and head aches for the building owner, but hey who cars right they got to work.
There are cold weather tips and techniques like keeping the shingles warm, which isn't realilstic IMO since a good crew can bang up a square in a half hour per roofer (after t.o). Where ya going to store 20 squares? Hand nailing is another cold weather technique. CertainTeed master shingle applicator manual suggests sealing each tab with roofing cement. One guy in Alaska says he tarps off entire buildings, like masons do in my area.... The problem I have with all this extra work is that who is going to compensate me for the extra time? If I take on extra risk for less reward, I might as well stay home. There's enough risk already. Then again if I am going to take on more risk for more money, we can talk.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 02-06-2010, 12:30 PM   #4
Residential Roofer
Slyfox's Avatar
Agreed, if the builder is not willing to pay for extra's than I won't be the one out there installing their roofs.
I supply a list of all possible extra cost items to the Builders/GC's I work for so they know to expect to pay more on winter installs.
I have to remove snow before installing the roof, that's an extra.
I have to have a "warm" area to heat any shingles that will be formed through valley's or ridge caps, that's an extra.
I have to use tarps for easier snow removal, that's an extra.
I have to use additional scaffolding for added safety issues, that's an extra.
Fortunately the Builders/General Contractors I work for don't fight me on my extra's, they will question them from time to time but once I explain what's what they are ok with it being that their roofs are getting done on time with out sacrificing quality.
Edited to add:
I can think of several builders/gc's in my area who do worry more about dead lines than quality,
but not all builders/gc's are like that, the majority of builders/gc's maybe, but not all.
A few in my area that care enough to wait/pay a few extra bucks to get it done right,
Don from Restle Builders, Tim from Kinowski Construction, Steve from Delucia Construction, Gene from Russo Builders, etc.
Facebook <> Twitter
Old 02-07-2010, 08:59 AM   #5
MJW
Typically that is a myth told by companies who have labor that goes South for the winter.
We have put on roofs for 30 years working year round here in MN, and had very few problems. In the last 5 years, we have had no problems, but that may be because we have better quality control with fewer guys now.
I would trust a roof put on in the winter over a roof installed in 90+ degree temps. The shingles actually work better cold than they do when the temps get above 80.
MJW is offline   Reply With Quote
Old 02-07-2010, 12:28 PM   #6
Residential Roofer
Slyfox's Avatar
I agree, extreme heat during installation is at the least as bad for the shingles as what the cold is.
Facebook <> Twitter
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Need HELP swapping a Vision pro 8320u1008 to an IAQ one N01B4ME HVAC 161 01-10-2011 02:30 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
how to stop condensation on windows? cake General DIY Discussions 7 11-22-2008 12:12 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
