Tar & Gravel Roof - How To Remove - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-14-2007, 03:10 PM   #1
Tar & Gravel Roof - how to remove
We have a small roof that needs to be replaced. Currently there is a balcony over the roof, therefore, we will have to dismantle the balcony first. The roof under is tar and gravel. The area below the roof is a kitchen and there is moisture building up in the ceiling, as we've been told the tar/gravel is probably old and water is getting in during rainy times.
Because it is less than 100sq feet, many contractors won't touch it. Therefore, I may be left to do it myself. How difficult is it to scrape tar and gravel from a roof? Do I need to reheat it or something?
once I have it off, how to I resurface the roof? I have looked at certain sealants, but am not sure if that is all I need to do? If it were that easy, everyone would do it and contrators would be out of busines.
Any suggestions?
DGH333
dgh333 is offline   Reply With Quote
Old 11-14-2007, 05:47 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I'm sorry to say this, but I think you're going to be in over your head. What if any background do you have at 'flat-roofing'?
tinner666 is offline   Reply With Quote
Old 11-14-2007, 11:22 PM   #3
unfortunately, I don't have any experience with any type of roofing. Since buying my home a few months ago, I have been quickly learning everything, from electrical to plastering, to plumbing. However, I completely realize there are some jobs I am not ready to tackle, nor do I have any right to try. This may be one bu thought I'd check to see just how detailed it is.
Thanks.
Old 11-15-2007, 12:42 AM   #4
Scraping the gravel and then saturating a coating over it will cause you more harm than good.
It can be recovered with a hard board insulation and a single ply roof membrane. Even most small contractors can do a modified bitumen roof system.
Ed
Ed the Roofer is offline   Reply With Quote
Old 11-19-2007, 12:47 PM   #5
Rewards Points: 150
I would not recomend hardboard "fiberboard" type insulation if you ever had a leak it absorbs water like a sponge and ruins the whole roof and promotes rot. You should pay a little more and use polyisocyanurate also known as ISO board. In short, shop for a good flat roofer.
RooferJim is offline   Reply With Quote
Old 11-21-2007, 01:43 AM   #6
the roofing god's Avatar
Send a message via MSN to the roofing god
definitely have a pro do it,especially if you plan on re-installing a perimeter railing
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 11:27 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
gravel roof marc4050 Roofing/Siding 7 10-05-2006 11:44 PM
Tar and Gravel Roof in Florida miamitom Roofing/Siding 2 03-04-2006 05:55 PM
replace tar & gravel roof with shingles & torch down rt1035 Roofing/Siding 4 12-17-2005 06:39 PM
