-   -   Tar & Gravel Roof - how to remove (http://www.diychatroom.com/f9/tar-gravel-roof-how-remove-13428/)
dgh333 11-14-2007 02:10 PM
We have a small roof that needs to be replaced. Currently there is a balcony over the roof, therefore, we will have to dismantle the balcony first. The roof under is tar and gravel. The area below the roof is a kitchen and there is moisture building up in the ceiling, as we've been told the tar/gravel is probably old and water is getting in during rainy times.
Because it is less than 100sq feet, many contractors won't touch it. Therefore, I may be left to do it myself. How difficult is it to scrape tar and gravel from a roof? Do I need to reheat it or something?
once I have it off, how to I resurface the roof? I have looked at certain sealants, but am not sure if that is all I need to do? If it were that easy, everyone would do it and contrators would be out of busines.
Any suggestions?
DGH333
tinner666 11-14-2007 04:47 PM
I'm sorry to say this, but I think you're going to be in over your head. What if any background do you have at 'flat-roofing'?
dgh333 11-14-2007 10:22 PM
unfortunately, I don't have any experience with any type of roofing. Since buying my home a few months ago, I have been quickly learning everything, from electrical to plastering, to plumbing. However, I completely realize there are some jobs I am not ready to tackle, nor do I have any right to try. This may be one bu thought I'd check to see just how detailed it is.
Thanks.
Ed the Roofer 11-14-2007 11:42 PM
Scraping the gravel and then saturating a coating over it will cause you more harm than good.
It can be recovered with a hard board insulation and a single ply roof membrane. Even most small contractors can do a modified bitumen roof system.
Ed
RooferJim 11-19-2007 11:47 AM
I would not recomend hardboard "fiberboard" type insulation if you ever had a leak it absorbs water like a sponge and ruins the whole roof and promotes rot. You should pay a little more and use polyisocyanurate also known as ISO board. In short, shop for a good flat roofer.
the roofing god 11-21-2007 12:43 AM
definitely have a pro do it,especially if you plan on re-installing a perimeter railing
