Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-03-2011, 05:01 AM   #16
Taking off Soffit Vents to clear insulation
John W, you may like to consider solving your heat problem by covering the rafters with a SIPS layer before fitting the new roof.
SIPS are a sandwich of polystyrene with oriented strand board or plywood on either side.
A SIPS roof works because there is no direct connection between the surface exposed to the sun and the frame of your home.
At the moment the type of insulation you have, while doing a reasonable job of keeping you warm in winter, does not stop the heat from reaching the inside of your home, this heat mainly arrives through conduction.
A five inch layer of polystyrene, that is 98% air and 2% plastic will stop this heat movement by conduction making your home a lot more comfortable.
Once you have done the roof, think about doing the south facing side/sides of you home.
Perry525 is offline   Reply With Quote
Tags
roofing, soffit, ventilation
Installing Soffit vents w/finished attic Nathan0115 Roofing 6 06-04-2010 10:05 PM
Boarded over soffit vents Jim F Roofing 6 04-21-2010 11:10 PM
Odd Sized Soffit Vents vball Roofing 1 09-08-2008 06:18 PM
Powered Attic Fan question spup345 Roofing 9 06-30-2008 09:10 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing 2 05-01-2007 12:14 AM
