T & G Roof Repairs - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-26-2013, 11:56 AM   #1
T & G roof repairs
Hi folks. I have an old house built in the early 40's. It has a cedar T & G roof. The boards are seperating and I'm getting water leaks where shigle nails have missed the boards. And of course I found this out after the kitchen ceiling started showing water stains!
So my question is, how can I fix the gaps between the T & G boards. Is there anything I can apply from the inside? Any advice is appreciated.
Mike
Mikehd08 is offline   Reply With Quote
Old 10-26-2013, 12:28 PM   #2
Rewards Points: 12,886
Got a picture of this roof?
No way is a few missed nails causing the leak, really old shingles?
There is no fixing it from outside.
If the roof was stripped I'd suggest going over the whole roof with a layer of 1/2 OSB or plywood.
Old 10-26-2013, 12:36 PM   #3
thoughts?
Thanks Joe....the shingles are only about 7-8 years old. From the inside, up in the attic, i can see the water dripping right at the gap between boards. I agree the proper way to fix this old roof would be to put new plywood over it and new shingles. But it's almost winter here and we can't do this until spring so I'm looking for a temporary fix until then. Could I use any of the brush on roof patch stuff that comes in cans? I'm thinking 'anything' that can fill in the gaps for now. It's about a 2 sq ft area so not a big space.
Old 10-26-2013, 12:52 PM   #4
I would remove the shingles and tar paper in that area, Cut out the T& G at least enough so the patch will span two rafters and no narrower then 24" then Add two layers of paper or better Storm and ice shield and reinstall new shingles.
I suggest it's not the cracks because it's possible to lay shingles without even any tar paper and not have it leak. If they over drove the shingles and blew the nails through them that may be why it's leaking.
Old 10-26-2013, 01:00 PM   #5
I suspect thats exactly why it's leaking Joe. I'm sure the nails are thru the shingles and right into the gap between boards. Like I said, given the weather here I have to look at an indoor fix from the attic side. That's why I thought about just filling the gaps. In the spring I plan on getting the whole thing done properly.
Old 10-26-2013, 01:26 PM   #6
It's impossible to fix on the inside!
kwikfishron (10-26-2013)
Old 10-26-2013, 05:53 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 934
Flex seal...?
No...not really. Joe is right.
Old 10-26-2013, 06:41 PM   #8
kwikfishron's Avatar
Rewards Points: 92
As JoeC has mentioned a couple of times now (and I'll take it a step further). THERE IS NO, zero, nada even the slightest chance no matter how hard you search the net or want to believe that infomercial that you can even temporarily solve this from the inside.
The ONLY thing you can do from the inside is place the bucket in the right spot.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Gymschu (10-26-2013)
Old 10-26-2013, 06:52 PM   #9
Rewards Points: 92
[QUOTE=Windows on Wash;1258421]Flex seal...?
That's funny...I just did a roof to wall leaker, when I showed up there was a black stripe running up the base of the siding and the white 3-tab. A 60 year old lady got on that roof and sprayed that stripe. The only winner was whoever collected that $19.95 + s/h.
Old 10-26-2013, 08:52 PM   #10
Roofmaster
Rewards Points: 2,172
Have you owned this house for a while? Chances are someone put a hole in your roof putting up lights, or nailing in a cable to a satellite dish etc. Chances are your T&G is yellow pine or fir, not cedar, but maybe you are right. Does it have that great cedar smell?
I would just go up there with a wonder bar, some felt and a hand full of shingles and fix the leak. If the area is not too big you can usually get away with a piece of 24 gage galvanized steel sheet on top for support, and some wood blocking between the rafters below, it really just depends on how extensive the problem is.
Pictures always help, just shoot it from below.
Protecting patio roof from water comming from house roof alekas Roofing/Siding 2 07-30-2013 10:40 AM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 04:42 PM
Leaky Roof Repairs jfm617 Roofing/Siding 1 07-03-2007 12:43 PM
