T&g - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-22-2010, 03:38 PM   #1
T&g
I am re-roofing a patio cover and it has tongue and groove boards. What size nails would be best for the tar paper and the roll on shingling?
CSLentz is offline   Reply With Quote
Old 02-22-2010, 08:49 PM   #2
Registered User
Rewards Points: 526
Low pitched? Roll roofing? 3/4" T&G? 1-1/2" T&G?
Be safe, Gary
Old 02-23-2010, 12:15 AM   #3
If your worried about nails coming through the bottom,you could always add a layer of plywood over the existing.Or did I miss the point?
johnk is offline   Reply With Quote
Old 02-23-2010, 07:03 AM   #4
Where are you located....snow load ?
Pine T&G Flooring AJ&J Flooring 2 03-13-2011 01:26 PM
4' T&G planks, NO staggering = POed home owner iMisspell Roofing/Siding 8 09-04-2009 10:14 AM
T&G porch repair porcher Carpentry 4 08-25-2009 12:13 PM
Installing T&G with crown on ceiling Rionewberry Building & Construction 12 07-17-2009 11:06 AM
Vaulted Pine T&G Ceiling Jambo Diego Building & Construction 1 05-08-2009 05:59 AM
