| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Check a Roof for Leaks
by eHow.com
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
How to Seal Drafty Air Leaks in Your Home
by eHow.com
There are many areas in the average home that are subject to drafts and air leaks. Whether it's dropped ceilings and window frames or air ducts or furnace flutes, chilly homes in the winter are unfortunately the norm. Air infiltrates into and out of your... Read More »
How to Make Doors Energy Efficient
by eHow.com
One area where homes are less energy efficient is around doors. Many older doors leak around their edges, and many others are simply not insulated enough to provide good energy efficiency. Making doors energy efficient is one of the most obvious ways to... Read More »
Gasket Reuse versus New Gaskets
by Expert Village
Hi, my name is Nick McCullough on behalf of Expert Village. In these clips we're going to talk about the proper way to remove and replace an engine valve cover, that is cracked, excessively worn, rusted out, or otherwise defective. In this clip we're... Read More »
How to Seal the New Gasket in Car
by Expert Village
Hi. My name is Nate McCullough on behalf of Expert Village. In these clips, we're going to talk about the proper way to remove and replace an engine valve cover that is cracked, excessively warn, rusted out or otherwise defective. In this clip, we're... Read More »
