Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-17-2012, 10:51 AM   #1
Sweating roof shingles over Catherdral Ceiling
I have a 20' x24' ft sunroom with a sloped ceing 14 ft high at the highest point. Ther is no attic over this room, justing a woodensheeted ceiling and the insulated roof. My roof is sweating under the shingles. Moistures is constantly running out from under the shingles in one area and onto the deck below. Anysuggestions on how to fix this?
coniethom is offline   Reply With Quote
Old 03-17-2012, 01:16 PM   #2
A picture or two sure would be nice.
What's the pitch of the roof?
Old 03-17-2012, 08:32 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
First off; Your location details (regional weather conditions, temps, etc.) would help.
- Build Well -
Old 03-21-2012, 08:48 PM   #4
Remodeling Contractor
you need to find out where this excess moisture is coming from first. Then get this fixed and the roof may be fine. do you have a new slab on grade floor? A lot of plants getting watered but no exhaust ventilation? Are there recessing lights in the ceiling? As mentioned... location? these issues are different for different climate zones.
Can I put shingles (or gravel) on top of torch-down roof? cbru Roofing 11 11-17-2010 11:24 AM
1/12 sloped roof leaking w/ asphalt shingles, replacement ideas? Tuffguy610 Roofing 3 03-17-2010 06:59 AM
Spray foam insulating ceiling under flat roof Jed Lukewater Remodeling 1 01-12-2009 08:22 AM
Cathedral Ceiling Insulation/Reflective Roof Coatings badnewsbair Roofing 3 06-18-2008 05:31 PM
Improperly installed roof ktpersh Roofing 1 05-15-2008 07:57 PM
