Sweating Interior Walls In Summer After New Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-11-2011, 12:24 AM   #1
Sweating Interior Walls in summer After New Roofing
I have been experiencing sweating hallway walls every summer (Southeast US) after a complete new roof was installed on my home. The sub roof and one layer was installed. I feel this is the best forum to post this topic b/c I suspect it is caused by improper roof board installation. Has any one experienced this situation before.
Thank you.
Tamara
Tamarareynolds is offline   Reply With Quote
Old 04-11-2011, 09:17 AM   #2
IR Tech
Danko's Avatar
Maybe lack of vents?
Hi,
probably the airflow throughout the house was reduced by new boards & shingles. Not that it should be there...But if the roof was the only thing that was done, this could be the problem.
Did they install the same amount vents on the roof? Did you insulate the attic when the roof was done?
thanks,
Danko IR Tech
Infrared Home Inspection
Infrared Building Inspection
Danko is offline   Reply With Quote
Old 04-11-2011, 10:42 AM   #3
Roof/Vent/Sweating Walls
Thank you Danko for your speedy reply. I did not insulate and we did put up the same amount of vents and whirly gigs. The roofers did not remove all of the old board as I think they should. They said it wasn't necessary. This I believe has created the problem. How do i remedy the sweating walls?
Old 04-11-2011, 04:29 PM   #4
IR Tech
Danko's Avatar
Heres a link, hope this helps....
http://answers.yahoo.com/question/in...6180105AAVI9tw
Danko IR Tech
Moisture Detection
Infrared Roof Inspection
Old 04-11-2011, 05:53 PM   #5
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Thank you.
Tamara
Is the a/c unit in the attic? You may have a loose return duct up there pulling in hot moist air. Could have been knocked loose by the roofing process, might just be a coinky-dink that it started after the new roof was installed. There should be no correlation between the re-roof itself and the problem you describe if nothing else was changed (ie, venting, insulation). It's more likely something wrong with the a/c equipment.
seeyou is offline   Reply With Quote
Tags
roofing; sweating;
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 06:10 AM
Metal roofing questions Axhammer Roofing/Siding 17 08-10-2010 10:10 AM
Multiple Roofing issues on my home. *HELP!* 2bsure Roofing/Siding 4 12-16-2009 10:29 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 07:09 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 06:32 PM
