Suggestions On Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-05-2015, 05:44 PM   #1
Rewards Points: 343
Suggestions on shingles
My mom is looking at having a new roof put on her home in Texas. They are looking at shingles, two of the roofers wanted to use Owens Corning, but OC got pretty bad reviews. I am wondering what suggestions you guys have. The quality is more important than the cost for her and she lives off a lake that might have stronger winds at times
Solaritu is offline   Reply With Quote
Old 07-05-2015, 05:52 PM   #2
Rewards Points: 50
Owens Corning is fine, but you want to go with their higher end shingles like the Duration which are better made and have a reinforced nailing strip, then make sure the roofer installs them with 6 nails per shingle and they'll hold up as good as any other shingle. The biggest variable on roofs by far is really the installation, a bad roofer can use the best materials you can get and you'll end up with a troublesome roof, so pick a roofer with the best reputation and have them install the best shingles they prefer to work with.
troyks is offline   Reply With Quote
Old 07-05-2015, 08:01 PM   #3
Rewards Points: 386
Just get more quotes if you aren't satisfied with what you have heard so far. For a job as $$ as a new roof don't hesitate to get lots of quotes. You will find that each roofer is sort of tied to a brand of shingle that they are trained in and prefer.
Definitely upgrade to architectural shingles (10-20% more) over standard three-tab shingles, they look much better. You can probably also get quotes from roofers that will use GAF or Certainteed shingles, they are both good.
Just to see the difference between three-tab and architectural shingles, look at the Home Depot or Lowes website for pictures.
To help decide which bid to take, ask around the neighborhood wherever you see an obviously new roof. Check a company out on the local BBB website.
ChuckF. is offline   Reply With Quote
Old 07-05-2015, 08:55 PM   #4
Rewards Points: 476
Architectural for sure. Easier and faster to install, last longer. Ron
ront02769 is offline   Reply With Quote
Old 07-06-2015, 05:49 AM   #5
craig11152's Avatar
Rewards Points: 298
Shingle failure is pretty rare so you likely won't go wrong with OC, GAF or Certainteed.
As troykc said the installer is really more important. 99.9% of peoples problams are installation issues which the manufacturer has nothing to do with. If you wake up in the middle of the night with a leak around a skylight or chimney or side wall its the guy who did the work that is responsible.
Around my area workmanship generally comes with a 10 year guarantee. A workmanship warranty is NOT the same as a material warranty. One comes from the installer one comes from the shingle manufacturer.
Don't look at me. I didn't vote for either one of them.
craig11152 is online now   Reply With Quote
Old 07-09-2015, 09:10 PM   #6
Registered User
Rewards Points: 526
Lighter colored shingles- some savings, pp.10, 11; http://www.floridabuilding.org/FBC/p...eportFinal.pdf
Gary
Old 07-12-2015, 07:31 AM   #7
Rewards Points: 786
Don't take roofer's word for it. Ask the neighbor, try to remember. How many layers of shingles are on the roof? Is the roof ok for even a second layer?
carpdad is offline   Reply With Quote
Old 07-12-2015, 03:24 PM   #8
Rewards Points: 3,857
IMO, One should never do a nail-over. Remove old, solve any problems, install new.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 07-12-2015, 04:12 PM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,204
I would always pull it as well if it were me.
making starters from Arch. Shingles diyroofer Roofing/Siding 13 09-19-2011 08:52 AM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Energy Star Qualified Asphalt roofing shingles? Scuba_Dave Roofing/Siding 50 09-28-2010 02:25 PM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 06:50 AM
