Stripped And Re-shingled, How To Fix Gap Between Siding And Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-18-2011, 07:01 PM   #1
Stripped and Re-shingled, How to Fix Gap Between Siding and Shingles
We recently started reroofing our house, and I have run into a problem that I'm not quite sure how to handle. The house is a 1 1/2 story, with a dormer on the back of the house. The roof had three layers of three tab shingles (blah!) before we stripped everything off and put down 30# felt, ice and water shield, and Timberline "Natural Shadow" architectural shingles.
The problem that we are running into, is that when they (the previous owners) resided the dormer, they only sided down to the top of the shingles at the time. So, obviously, when we stripped three layers off, and only put on one, this created a gap where the siding doesn't meet the roof (images attached.)
My question is, what is the best way to fix this gap? Tar and flashing of some sort? Do I have to reside the dormer (would definitely prefer to avoid that!)
Thanks, in advance, for the help.
Stripped and Re-shingled, How to Fix Gap Between Siding and Shingles-img_1620.jpg   Stripped and Re-shingled, How to Fix Gap Between Siding and Shingles-img_1621.jpg
woodsbw is offline   Reply With Quote
Old 06-18-2011, 07:47 PM   #2
kwikfishron's Avatar
Rewards Points: 174
You defiantly have a mess on your hands there Wood.
Not so much the gap as much as your attempt to reuse the step flashing and nothing in a tube or can will solve this.
The siding should be held up off the roof at least ¾”.
You need to “properly” install new step flashing. IMO the only way to do that is to remove the siding, especially since it’s vinyl. The wall side of the new flashing should be against the sheathing and behind the WB of the siding.
kwikfishron is online now   Reply With Quote
Old 06-18-2011, 10:57 PM   #3
That step flashing needs to be replaced as well as the flashing around the cast iron pipe.
BamBamm5144 is offline   Reply With Quote
Old 06-19-2011, 12:53 AM   #4
Replace Siding?
So, in this situation, could I just remove the siding, replace the step flashing, and reuse the siding? Or, would the bottom line of the siding still be to low?? Would I have to reside the whole dormer?
Old 06-19-2011, 03:35 AM   #5
Pipe Flashing?
BamBam, what's the issue with the pipe vent? That is actually new flashing...although I would like to remove the gob of white stuff from the top of the pipe.
Old 06-19-2011, 08:03 AM   #6
Rewards Points: 174
Yes you can reuse the siding. I’d drop it down though. Set a 1x on the roof then set the J on that.
If you do that you’ll have to re-cut the siding which will leave you short at the top so you’ll need to buy a few panels.
