String Wire Thru Flat Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-22-2004, 01:03 PM   #1
I need to put a Antenna wire down through the flat roof on a Santa Fe style home to accommodate an entertainment center in the midle of the house. Is there some sort of apparatus that is designed for this? If so, where would I find one? Thanks.
Jamie Girard is offline   Reply With Quote
Old 06-22-2004, 05:46 PM   #2
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
I highly recommend against this but it's done all the time with HVAC. Check a roofing supply shop and ask for a wire penetration flashing.
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 02-18-2005, 09:28 PM   #3
Commercial Roofing
AaronB's Avatar
There's got to be a better way.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 02-18-2005, 11:01 PM   #4
Contractor
Marine stores have what they call 'cable outs' they also carry a sealant called 5200 made by 3M. 5200 is made for constant pressure below the waterline on yachts. Install the cable out per directions and goob the entire install with the 5200, be liberal. Anchor the cable as near as possible to the co to prevent flexing. Pray to God that you don't have to remove it. Liberal amounts of mineral spirits on a rag, not paper, will clean up 5200 prior to curing. After that all bets are off, a heat gun will soften it.
Teetorbilt is offline   Reply With Quote
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 05:25 PM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 07:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 11:12 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 09:34 PM
